what trans fluid do you guys run?
[QUOTE=TexasCTD;2698422]I run what my 30 year trans builder told me to run.......Good ole Mopar ATF +4 and change it out regularly....say every 20K miles or so. Also, it is synthetic.
Same here my trans builder suggested Mopar ATF+4, and change it about every 30K.
[QUOTE=jmmcdona;2698502]Interesting... The trans builders I talked to told me that with the red alto clutches not to use the atf+4 due to it having a lot of friction modifiers something not wanted with racing trans.
Although I occasionally run my truck down the track, It is not a dedicated race truck. I daily drive it, tow with it etc. The trans is smooth as silk but it hooks up and gos.
If the trans was born made to run Mopar ATF +4 and it works great, why change?
the oem clutch require atf+4 my red eagle clutches can use either. My fluid costs $10 a gallon. I DD my truck also Mine also shifts very smooth but when I hammer down on it the shifts are quite firm
I guess either fluid will work then. I have upgraded clutches also. I have just used ATF +4.
UnrulyNFS
Feb 21, 2007 08:21 AM
drcook
Sep 15, 2006 11:24 AM
CruisingRam
Jun 3, 2004 09:36 PM
