What Tires do you guys run?
I want to get a set of tires for my truck. I am running size 265 tires now and will stick wit them. I want to get a set locally that will last me as many miles as I can get out of them. I do go off road occasionally but need E rated tires.
Let me know what you are running and how many miles you are getting out of them.
Bob
Bob
Nitto Terra-grapplers
http://www.tirepackage.com/Tires/Ter...0805&t_pl=3284
I bought my '01 with 285/75/r16 yokohama geolander a/t s on it they have been great as a winter tire and have 20,000 miles on them and they are good for another 20,000. I do spin tires at times
. I also run 33/12.5/16.5 in the summer. Usually BFGs though my last set of m/t used a lot of tire weights. I have a 2 inch spacer to make the 33's fit
i had a set of nitto TG's and was very dissapointed with them. i now run a set of E range Goodyear Wranglers. i havent had them on for very long maybe 5-7,000 miles but they still look new, they are quiet and are wearing great, still look new. ok for going off road but if you plan on doing it alot then i would go with a more agressive tire.
I run the Toyo Open Country AT's , 265-75 R16 Load E. About 10,000 so far.. rears are still like new... Fronts are showing wear but that due to other front end problems and I run the truck hard in the winter and plow snow. I got alot of weight on my front end when it snows and I'm in 4WD. I love them. I am in the process of fixing my front end to avoid killing the fronts and then I'll be rotating! I recommend them.
I run Dayton Timberline MT's 265/75/R16 amazing tire in the snow. I have D range one mine and they dont complain about my meyer plow in the winter. Good road manners great in the wet and dry. almost 10k on mine so far and still look new.
im running hercules terra tracs on my 97. good all around tire. and VERY smooth riding compared to the wrangler rts i had before. not the best in mud but they take care of buisness if they need to. i figure the rate they are wearing right now ill get around 60K out of them.
