At what point does a fuel upgrade add noticeable power?
Old Sep 18, 2007 | 12:56 PM
jmccart's Avatar
Like it says. At what point will an upgraded fuel system give me reason to appreciate the money spent?
Thanx.
Old Sep 18, 2007 | 01:00 PM
#2 only's Avatar
The cetane point quality should be at least 40, anything above that won't be harmful, but won't help power or mpg either.
Old Sep 18, 2007 | 02:07 PM
jmccart's Avatar
Thanx #2 only. I was talking of fuel quanity, like a FASS or something. Is that what you are talking about and I just don't get it?
Thanx.
Old Sep 18, 2007 | 02:24 PM
#2 only's Avatar
No,I'm sorry,I did'nt read it closely.I would say over 400 horses.
Old Sep 18, 2007 | 02:52 PM
goodeyesniper75's Avatar
i noticed a difference in low end and top end with mine and at the time had about 350 to the wheels, now im pushin more and can def. see how it was a worth while mod at the time even if i didnt need it until now.
Old Sep 18, 2007 | 03:22 PM
JCLeary's Avatar
For me, the gratification was instant after the FASS 150 install. There were several reasons:
- No longer did I worry about something passing through the stock 10 micron fuel filter and toasting my injectors. I was using 2-micron Fleetguard filters.
- Draining the water separator was easier.
- My fuel pressure went from 7 psi to 20. It no longer drew down to zero causing the truck to feel flat. It remained at about 13psi at WOT with the boxes set to kill. With the stock pump/filter I think at around 400-ish hp is where I noticed the drop.
-It was reassuring to hear my FASS running when the truck was running after I turned off the key (using the TST cool-down timer). It made me feel a lot better than not knowing if my CP3 was having to draw fuel all the way from the tank.
Getting a Glacier setup with the filter and big line kit is high on my list of mods, even before power-adders. I want to do everything I can to keep my injectors in good shape.
Old Sep 18, 2007 | 04:28 PM
SSminnow's Avatar
Amen to that! (even though I run teh Walbro from Glacier)
Old Sep 18, 2007 | 04:40 PM
rip 112's Avatar
I would say even stock you would gain benefit. Aftermarket pumps are way more reliable in any circumstance. That is reason alone for me.
Old Sep 19, 2007 | 12:03 AM
matego's Avatar
madhat's monkey boy...
I am going to be a little different and say it depends on how you make the power. My hot juice could pull the stock pressure down to 4 psi on #5 (180 hp) but the MP-8 set to 65% (maybe 50 hp) could pull it to 0-1 easily. On my truck anyway, pressure really kills the stock lift pump. I think I could feel a difference stock when I put on the walbro set to 23 psi @ idle. I also have the DIY CP3 done, which may make a difference in all of this.
Old Sep 19, 2007 | 12:52 AM
jwb600's Avatar
lots of mods need more fuel, thats what ive got a fuel system.
you cant run lots of stuff without one. it was one of the first mods on my truck
Old Sep 19, 2007 | 09:41 PM
DaveB.inVa's Avatar
I ordered my Glacier pump and Smarty about a week apart. I got the pump on and ran it about a week before I got the Smarty. Even stock the idle is smoother and there is a slight improvement in responsiveness.
bngcustoms
Jul 17, 2009 04:53 PM
dodgemaniac
Jun 12, 2007 08:21 AM
omaharam
Sep 11, 2006 06:31 AM
6cylinders
Apr 20, 2004 11:11 AM
doomgaze
Dec 25, 2003 09:09 PM
