how noticeable, 275's?
Old Apr 19, 2004 | 09:33 PM
6cylinders's Avatar
I just ordered Bosch 275's and was wondering what kind of
power increase I should expect. How noticable will it be?
Old Apr 19, 2004 | 11:05 PM
mooseman's Avatar
just put the same set in mine and didnt notice much at all. maybe a little more smoke.
mooseman
Old Apr 20, 2004 | 12:41 AM
GlennRMK's Avatar
My buddy has a 98.5 auto and had 100hp DD Stage 3s. Now he has the RV injectors(thought the Stage 3s would fry the tranny) and the difference is huge. The truck was a lot quicker with the Stage 3s.
I would go Mach 1.5 or 2s if I were you.
Old Apr 20, 2004 | 06:54 AM
bluebull's Avatar
275's will add approximatly 35-40 Hp. On these heavy trucks it's very hard to notice a 35-40 Hp increase. To keep from think you cheated your ownself do 0-60 times before the installation and then after the installation. This was the only way I could tell I added stage 1 injectors and they gave me a solid 60 extra Hp as later determined by dyno testing.
Old Apr 20, 2004 | 07:30 AM
Palmetto_kid's Avatar
Re: how noticeable, 275's?
A little late for this question huh?
Add an EZ ( built in boost fooler). It will help you notice the diff. Being limited to 20psi will hold you back for sure.
There are a few EZ's for sale in our classifieds for cheap.
Old Apr 20, 2004 | 09:16 AM
gandrews's Avatar
When I first got the truck I put on the Banks Power Pack. It included the ottominder fueling box, a wastegate modification and 4" exhaust & a few other items. It added a noted difference. Shortly after that I put in some RV 275's and I really noticed the difference.
From what I have read here it seems to be the consensus that ETH's like injectors more than ETC's but that ETC's get more out of the boxes. So that may be why I noticed the difference and some of the others didn't.
Anyway I think the RV275s will Then a box and boost fooler
Then you will need just a little more and then just a little more
Good luck
George
Old Apr 20, 2004 | 10:45 AM
surfram's Avatar
What torque increases are possible with just RV275s on a 2001.5 SO/auto? This is a friend's truck that already has a banks 4" exhaust and a K&N drop-in filter.
Old Apr 20, 2004 | 11:11 AM
rattle_rattle's Avatar
I started out by installing an Edge EZ. The change was incredible! I installed RV275's later and the change was also incredible! I'm at the limit of my clutch now. As for smoke, I can also make the road dissappear behind me in low boost situations. As for boost, I'm getting 38PSI WOT at around 2200 RPM. I did start out with an HO though.
jmccart
Sep 19, 2007 09:41 PM
moneyman
Jan 24, 2003 05:40 PM
bdog
31
Jan 10, 2003 08:08 AM
Monty
0
Nov 21, 2002 05:18 PM
drecu
Nov 8, 2002 01:41 PM
