what is a Galcier Diesel Walbro Kit (2005)
I see everyone talking about this kit and I'd like more info on it.
Does the pump take the place of the pump in the tank and use the factory lines running from the pump to the filter?
Does the pump use the factory wiring or do you need to run new ones?
Where can I get one of these's kits, and how much do they run?
Thanks CRIS
Thanks CRIS
Thanks CRIS
Thanks CRIS
http://www.glacierdieselpower.com/pr...?pf_id=3920506
$429
The '05-'06 kits are a little different than the '03-'04.5 units. We do use a separate pickup at the tank but the rest of the system actually runs parallel to the stock system right up to the connection at the filter housing. By using the same entry point at the stock canister the entire original system stays in place and sealed. We use a new electrical connection at the tank which allows the ECM to "see" continuity and trigger the new pump just like the stocker for priming and starting.
For the guys with modified CP-3's that need 35+ psi we eliminate the stock line altogether. I have a complete package (2 mic, Big Line and GFS) headed to a customer right now. He'll be going to Floor-it for a Stage 2 CP-3 after it's installed. Hopefully we'll hear right John how the GFS-392 does at 40 psi feeding a Stage 2 thru a 2 micron filter. Should be a great test!
Richard
Richard
Hey Richard I been meenig to get in touch with you, it seems you're lines always busy now though , I wonder why? Anyways, I will be getting your bigline kit you offer now, and work something out on the other pump you sent me to test out.
By the way, there is no way you can go wrong with this kit. AS I was a Beta tester, running into a few minor snags, there has been nothing but perfection out of this system for me.
It's a great time to do the vent mod also. If you add a couple of extra fittings you can use the capped off vent line for your return and avoid putting the return manifold in the fill neck. I've got my truck setup this way.
I think Rich just see who calls him and dosen't answer it
In all honisty, the kit is great. I love mine and to be honist I've only had to leave a message once (was late at night). But I love the kit, love the way it works.
If I ever get modded and need more fuel and all that, I may replace the stock plastic line by the fuel filter with the push locks so it'll take more pressure. I'm not gonna get that crazy though, Yet
UnrulyNFS
14
10-17-2006 08:57 PM
Raspy
36
05-23-2006 10:28 AM
BCarmicle
09-14-2005 07:27 PM
