Commander mounting option
Old Jul 24, 2006 | 02:39 AM
RacenutSB's Avatar
I didn't want my Commander above the dash so I came up with my own mount. I think it turned out pretty clean.
It's just a piece of lexan sheet cut and shaped with a dremel to fit. Then painted and used double stick tape to mount it. It holds real solid. I had to bend the lexan a bit to fit the shape of the dash better. Put it in the oven at 275-300 and it will bend easily. Careful, it only takes a little.
I ran the wire right through the vent, put a little notch on the inside for it to get out and through the hole where the headlight switch is.
Anyway.. it was easy and cheap. Only had a chance to play with the Commander a little bit, but so far I like it
Old Jul 24, 2006 | 10:03 AM
ptgarcia's Avatar
Looks good RacenutSB. Not sure how I'm going to do mine once it arrives.
Old Jul 24, 2006 | 07:31 PM
nwjetboat's Avatar
Nice looking mount Racenut. Mounting is the only issue holding me from purchasing a commander. I do not want some cobbled together looking gauges.
Old Jul 24, 2006 | 07:47 PM
RacenutSB's Avatar
Yeah, that made me a little hesitant too. The Attitude module certainly looks nicer, but the Commander offers functions the Attitude didn't. I went with function over form and figured I'd make the form work. I think it turned out just fine
Steve V.
Oct 1, 2007 09:49 AM
cjones42
Mar 16, 2007 11:06 PM
stock03
Nov 9, 2006 11:27 PM
Hummin Cummins
Dec 2, 2002 05:37 PM
RJMontana
Oct 23, 2002 05:06 PM
