Water Injection
Old Dec 1, 2009 | 06:57 PM
  #241
rock crawler's Avatar
It looks like the coolingmist CMGS-FS Diesel EGT kit is a nice kit. Anyone have experience with this kit? A little pricey though.
Old Dec 1, 2009 | 07:43 PM
  #242
Rpainter's Avatar
alcoholinjection.com makes a great kit and very well priced. Rob
Old Dec 1, 2009 | 08:37 PM
  #243
John_P's Avatar
Thanks for all the advice guys. Is it better to run the spray based on boost or egt? At WOT my boost reads about 45psi. I only plan on using the system for playing but if I decided to use it while towing would it be better to spray based on egt so that it will not consume so much water? The problem for me is that there are SO MANY options it gets a little confusing. Again, THANK YOU VERY MUCH for the help. BTW my intake horn has 2 large ports and 1 small port left free.
From my end,......you are very welcome rock crawler! I know that Robert feels the same way too. You are right that there is "alot of options" from "mild to wild!" But,......I know you will find a system that will work good for your vehicle.
Good luck!
Old Dec 1, 2009 | 08:49 PM
  #244
Rpainter's Avatar
Good luck!
getting kinda late for a man of your age john to still be up? what a new episode of golden girls on??
Old Dec 8, 2009 | 12:26 PM
  #245
rodriguez7's Avatar
So I just ordered the snow stage 2 kit. Going to be using it for hi egts while towing. Its been getting kinda cold here, supposed to be 18 tonight. I guess I can use windshield wiper fluid,as long as it doesnt have glycol in it right? And what kind of mix? I ordered the 7 gallon tank also. I was thinking 6 gallons of distilled water, and 1 gallon of the peak windshield wiper fluid. How does that sound? Is that enought to keep it from freezing? Is that to much meth for towing?
Old Dec 8, 2009 | 01:04 PM
  #246
RowJ's Avatar
Originally Posted by rodriguez7
... I was thinking 6 gallons of distilled water, and 1 gallon of the peak windshield wiper fluid. How does that sound? Is that enought to keep it from freezing? Is that to much meth for towing?
Peak, I think, is not a methanol mix? be sure to check the label. If it doesn't say Methanol...don't use it.
Your talking 20% meth in wiper fluid watered down x 6. 3.3% meth may not be enough , depending on your temps, and how long it stays below 32*. I'd go ALL Wiper fluid... in winter at least.
20% is not a lot of meth. Have studs?
RJ
Old Dec 8, 2009 | 02:19 PM
  #247
rodriguez7's Avatar
No I dont have studs. And yes peak had meth in it, dont know how much but it was the minus 20 stuff. So around 20% will be ok to tow with? Thanks. Is this to much cylinder pressure to not have studs?
Old Dec 8, 2009 | 03:41 PM
  #248
RowJ's Avatar
I know some of the 03 systems are still 2nd Gen stuff so it depends.......
If 03's have full metal gasket and are machined for head fit, like the later models...you're fine.
If not...if head and gasket are like the 2nd gens, I would not run meth at all, without studs.
RJ
Old Dec 8, 2009 | 03:52 PM
  #249
rodriguez7's Avatar
I think they are the same as the newer models. But im just going to run enough meth to keep it from freezing. Thanks for your help
Old Jan 3, 2010 | 03:52 PM
  #250
Bswope's Avatar
Just heard that Tim Barber is working on a 500 psi kit..... anyone have any info on this?? This has my attention!!
Old Jan 4, 2010 | 01:32 PM
  #251
John_P's Avatar
No, I haven't heard anything about that all. But,...I haven't talked with Tim in awhile either.
John_P
Old Jan 20, 2010 | 10:10 AM
  #252
RLL's Avatar
RLL
Anyone looked into running multiple smaller nozzles that have finer micron atomization than larger nozzles. I would think there would be better distribution of smaller water molecules than larger ones.
Old Jan 20, 2010 | 03:58 PM
  #253
John_P's Avatar
RLL:
Yes, I did awhile back and it helps, but it still does not do as good a job as putting the nozzles right into the ports of the intake manifold.
John_P
Old Jan 20, 2010 | 05:57 PM
  #254
Rpainter's Avatar
my nozzles are only 5 gph at 100 psi.
Old Jan 20, 2010 | 08:05 PM
  #255
RLL's Avatar
RLL
I'm still working on my setup but right now I have 10 2gph @ 200psi nozzles
I cant wait to get it all hooked up and try it out.
