update on the leaking turbo
First of all thanks for the advice I would never never thought there'd be oil on the intake side and there was! I took the boot off the oil literallyrun out a stream and the size of a pin head 10-12 minutes. I hope that's my only problem but............. before I took it apart I noticed smoke coming out the blow by tube when I put my thumb over it the smoke got way worse and pure white ?? Idk about the blow by or even what it dose but the white smoke means head gasket right????? If so how do I go about changing it?
a little puff of smoke out the blow by tube is ok but if you have excessive smoke AND oil coming out the blow by tube its usually a sign of a broken ring.
What was the deal with your turbo disappearing oil on the dipstick and it sounds like it was the seal on the intake side?
lilsuzuki4x4
09-01-2011 01:50 AM
RamWheelsBy4
08-24-2005 05:50 PM
