Twins - Smarty TNT - Boost Fooler?
OK...ya'll straighten me out.
What do you do to stop the overboost code with twins. Do you have to run a boost fooler with the Smarty? I have the WG turned off. I think I read (In another thread) where the Smarty fools up to 40 something pounds. Am I missing something?
Thanks,
Tanner
Thanks,
Tanner
DTR 1st Sergeant
Thanks,
Tanner
Thanks,
Tanner
Problem is the smarty has to use the factory readings from the ECM about the MAP sensor...
soulezoo......I should have just PM'd you. The info from the thread I was talking about was from you. I appreciate the quick response....I thought I was going to start looking for a resistor or something!
I went ahead and put the quad fooler back on. Will try it out tomorrow!
Thanks Again!
Thanks Again!
Get a Quad X2 Std. box and the problem will be solved. Just through the pressure tune in it and you will be golden. Even has a RP gauge built in so you can sell the one you have to recoupe some money.
Thanks Spooler....
I'll check that out. I have the race box (no timing)....but now its coming to light why everyone is saying that the MP8 is an expensive fooler for TNT.
I wonder if the rail pressure quage works with the race box? I'll have to give them a call tomorrow.
Thumbs up Dude.....Thanks for the advice. It's nice to have Quad right down the road!
Killdmycobra
11-12-2010 05:15 PM
-PowerWagon-
12-30-2008 01:06 AM
Rollin' Smoke
23
06-26-2007 09:04 PM
