turbo mounting stud broke!!!
Old Apr 2, 2008 | 04:18 PM
J-man's Avatar
I was towing a four horse gooseneck home from ID this weekend, and I suddenly had a very strange sound whenever i got over about 20 psi boost. When I got home, I saw that one of the bolts that attach the turbo housing to the exhaust manifold apears to have sheered off and I have an exhaust leak there, thus the sound. Has anyone had this happen before?
Old Apr 2, 2008 | 04:52 PM
J-man's Avatar
Bump! ANy comments?
Old Apr 2, 2008 | 05:06 PM
rmalone's Avatar
I haven't heard of that one, but holy crap!! Is it going to be a reasonably simple fix?? Is the other stud or either bolt beat up?
Old Apr 2, 2008 | 05:33 PM
J-man's Avatar
I don't see any other apparent damage. As far as how hard it is to fix, that is kinda what I am trying to figure out here! It looks like i have to remove the intake, and then the turbo itself to even see what to do about the stud or bolt or whatever it is. If it is covered on my waranty, I would rather someone else do the labor.
Old Apr 2, 2008 | 07:04 PM
WUnderwood's Avatar
are you sure the stud broke? if it did, there would be black soot all around the leak. is this what you have?
Old Apr 2, 2008 | 09:43 PM
bluechrome's Avatar
Your going to have to drill it out or you could try a easy-out
Old Apr 4, 2008 | 01:33 PM
J-man's Avatar
Yeah, that is what I've got. I talked to the dealer and they said that the engine waranty should cover it so it goes in to get fixed on Monday.
Old Feb 17, 2010 | 03:25 PM
moparmatt's Avatar
i just recently had this same problem it took me a few trys to find out what the noise actually was, mine eventually had a small amount of soot build up around the gasket.
Brian.B
Sep 5, 2014 06:25 PM
turboman1
Dec 24, 2007 10:04 PM
74dart
Jul 7, 2007 07:58 PM
Zackb911
13
Jul 28, 2006 10:40 AM
ram29
Sep 16, 2005 03:59 AM
