Turbo lag and boost?
Old Jul 2, 2008 | 02:02 PM
CoolumConst's Avatar
I have the HTT 62/65/13ss and 1.8 injectors and Revo #7. Driving around normal the boost will be 0 most of the time, without getting on it I have seen a high of around 5psi. If I get on it hard it will hit 39psi. From a dead stop and flooring it it takes almost 6 secs to raise the boost over 10 but then goes up fast, the truck moves a little bit for the 6 secs then takes off good.
Is this normal for a turbo and injectors?
Old Jul 2, 2008 | 02:37 PM
omaharam's Avatar
You will likely find that if you give it 3/4 instead of full throttle for the initial off line and then ease into 100% that it will actually be faster off the line and to build boost. You are overloading your turbo with too much initial fuel. Also, make sure your TM is on 4.
Old Jul 2, 2008 | 02:52 PM
It seems to be very easy to overload the turbo, I took the 4.2 off for that reason. How much did the twins help in spool and cooling?
Old Jul 2, 2008 | 04:40 PM
rip 112's Avatar
Omaharams words are spot on!
Looks like you're needing the 71 wheel for better drive pressure ratio.
Old Jul 2, 2008 | 07:34 PM
omaharam's Avatar
- Is that a good enough answer for you?
Old Jul 2, 2008 | 10:08 PM
I didn't go with the 71 because I am at 7000'. I will try 3/4 pedal and TM 4.
Old Jul 2, 2008 | 10:46 PM
Big Blue24's Avatar
How many miles on the turbo? Seems to take a while for new turbos to loosen up, a good 1-2K miles.
Old Jul 2, 2008 | 11:01 PM
about 800 miles
05smokemachine
Introductions / New People
Sep 24, 2013 08:01 PM
blueberry
Jan 11, 2006 12:46 AM
ptextreme
Mar 21, 2005 02:02 PM
MY WORLD
26
Feb 26, 2005 06:47 PM
J BODY
Jun 8, 2004 07:16 AM
