Tst & Edge
Tst & Edge
How do you stack these boxes together I have the edge ez laying around with only My TST on the truck. I was just curious how you would go about doing this. Thanks
Install both boxes normally. The only point of contention is the MAP sensor. Plug the TST into the MAP sensor on the intake manifold. Plug the EZ into the remaining TST connector, then plug the remaining EZ connector into the factory wiring harness.
Be careful not to run the fuel pressure to zero, or kill the stock (and rather fragile) turbo.
Mopar1973man
Nov 16, 2006 10:26 AM
Diesel 2006
Jan 26, 2006 02:10 PM
mjpalmer
May 19, 2005 11:34 AM
rockjeep73
Mar 25, 2005 03:34 AM
Patriot_RAM
13
Mar 1, 2005 08:26 PM
