Truck Lost Its Mojo.
Old Dec 18, 2006 | 10:15 PM
Swamp_Donkey's Avatar
My 04.5 has a edge juice with attitude with the hot program. Right now my truck is extremely gutless and will not go over 22 lbs of boost on all settings from stock to 5. There is a little more power as I go up levels but nothing like when it is working properly. What do you figure is going on? I use Tons of fuel conditioner and do not have a fuel pressure guage.
Old Dec 18, 2006 | 10:24 PM
Syndicate's Avatar
boost leak??????
Old Dec 18, 2006 | 10:54 PM
Guess I will check for that tommorow!
Old Dec 19, 2006 | 12:53 AM
Demodude's Avatar
We have been having tons of fuel issues with fuel out of Edmonton ever since the change in October to the new ultra low diesel, Lots of geling even at temps around -10, kind of unheard of. We usually change fuel filters on our machines every 3-4 months, lately every week! We've been using Howes fuel conditioner, it doesn't seem to help, but today our bulk dealer tested our fuel and is recommending a different additive, said kerosene helps, but is going to give me some samples tomorrow.
Old Dec 19, 2006 | 01:14 AM
ramtd02's Avatar
true, changed my fuel filter last week, and had too let the engine warm up first, filter canister was 1/2 full of water, i had drained it 2 days prior!!
Old Dec 19, 2006 | 01:38 AM
morkable's Avatar
John,, order some gen49 from nadp here in gp,, it seems to be working good in my truck right now,, but I wouldnt be supprised if it was fuel,, also,, do you know how to check your codes,,, turn the key 3 times,, you may have a code that is causing the problem,, if you still have my cel give me a call tomorrow and I can try to help you through it
Kevin
Old Dec 19, 2006 | 07:04 AM
trik396's Avatar
You really need a fuel pressure guage.
Old Dec 19, 2006 | 06:27 PM
Had no idea we were getting crap fuel. I am going on days off tommorow so I will dig into this issue a little more. Weather is around 0 here and I have been using Power Service every fill up for around 3 months. Only the recomended amount. People look @ me like I am crazy when I have my measuring cup out at the pumps!
Old Dec 19, 2006 | 06:34 PM
morkable's Avatar
LOL,, I hear ya,, I run gen49 every tank. If you are still having problems, give me a shout
Kevin
Old Dec 19, 2006 | 07:00 PM
acook's Avatar
People look at me like an idiot when im at the pumps with my measuring cup to!!
Old Feb 5, 2007 | 12:26 PM
Palmtree's Avatar
yea...I thought I was alone in feeling a bit strange when people look at me fussing with the additive levels at the pump. I use stanadyne with every fill. Haven't had any fuel issues up here (Alberta) but the truck was running rough while traveling through nevada last month, new fuel filter seems to have fixed it. So far.
southpawslingr1
Jul 9, 2008 08:44 PM
Swamp_Donkey
Feb 16, 2007 10:59 AM
bigfoot
Jan 29, 2007 09:18 AM
g
Nov 26, 2006 07:44 PM
DieselDaze
Jul 17, 2003 09:21 PM
