TrippleDog W/ Crazy Larry
Old Feb 21, 2007 | 07:58 PM
robertc82's Avatar
I run my tripple dog on performance all the time and every once in a blue moon when some gasser thinks he can take me I switch to crazy larry, run em, and right back to performance. Am I Asking for trouble without any tranny mods? I also drive like an old lady (no offense to old ladies) when I have it on performance. Should I be running on tow? What do yall think? Thanks
Old Feb 21, 2007 | 08:21 PM
jwb600's Avatar
I ran my triple dog on performance most of the time. I would do the same thing, put it on crazy larry to blow some smoke or race somebody. my tq converter got to where it would slip in overdrive if I would dog it out to roll some smoke. I would be careful with yours. I ended up just replacing converter and tranny so they didnt explode. my truck has 11k miles on it.
Old Feb 21, 2007 | 09:13 PM
preloader's Avatar
I run crazy every now and again. My truck still runs as good as new.
Old Feb 21, 2007 | 10:01 PM
robertc82's Avatar
If I bought a torque converter would this take care of my worries? How much would that run?
Old Feb 21, 2007 | 10:16 PM
jwb600's Avatar
a suncoast triple lock is 1300. that wont make the tranny unbreakable by any means. you can run a different valve body as well and it should help out also. many tranny builders told me with a 3rd gen if your buying a tq converter get an aftermarket flexplate also. the stock ones are weak.
Old Feb 22, 2007 | 05:03 AM
Rpainter's Avatar
you might want to upgrade the valve body to increase the line pressure your clutches will than you
Old Feb 22, 2007 | 07:11 AM
SMOKINDODGE06's Avatar
Will The Tc/vb/flexplate Be Able To Handle Crazy Larry? Ive Been Wanting To Run It In My Truck For A While But Im Scared That Im Gonna Eat The Tranny. So Im Plannin To Beef The Tranny. But I Just Dont Want To Under Do It When I Build The Tranny.
Old Feb 22, 2007 | 07:16 AM
Luvnacumns's Avatar
I ran Cl on my 05 all of the time, towing,driving no matter what I was doing. i did have analog guages and the outlook monitor so I could watcht the motor's paramater's but never did anything to the tranny! I wasn't stupid though... I was running a 6" lift with 37's and 20's. So as long as your smart you should be ok but nothing is fool proof.
Shane
Old Feb 22, 2007 | 08:14 AM
HotRodK's Avatar
Thumbs up
Can someone give us an estimate on the VB/TQ/Flexplate? And then for the install??
Thanks!
Old Feb 22, 2007 | 04:55 PM
jwb600's Avatar
tranny fluid is not cheap either. name brand stuff is $5 a quart. parts are 2200 that I figured for good stuff. then to have someone install it. may be 2500 or so. I know all the stuff together works great and holds alot.
Old Feb 22, 2007 | 07:26 PM
morkable's Avatar
My tranny with flex plate and deep pan installed was just under 6k canadian
Kevin
MOJO1
18
Mar 23, 2016 06:47 PM
smoky05
22
Nov 30, 2007 08:26 PM
huntingdeer
Sep 17, 2007 09:34 PM
HeberRam
Mar 30, 2007 05:37 PM
Snojumper
34
Mar 18, 2007 12:27 PM
