Tq managment disabled w/ cel
Old Nov 11, 2006 | 10:54 AM
acook's Avatar
I disabled my tq management a while ago on my bully dog and i got the abs, airbag, and emergency braked cel. I turned the tq management back on and i need to know how to clear the cel's. I know its a cycle with your key or something?
Old Nov 11, 2006 | 11:10 AM
HeberRam's Avatar
acook, go to the DTC's and clear codes...even if it says there are no codes, clear out anyway. Should work.
Old Nov 11, 2006 | 11:35 AM
acook's Avatar
Didnt seem to work?
Old Nov 11, 2006 | 11:33 PM
acook's Avatar
Anyone have any ideas?
Old Nov 12, 2006 | 08:48 AM
HeberRam's Avatar
acook, If you have an outlook monitor cut the power to it. I don't mean unplug from the OB11 port. Make sure all lights, cell phone , radio power etc. is off. Do the DTC's test again and clear. cycle the key (don't start) a couple of times. It should work??? This might sound stupid if it doesn't work, put it gear and go backwards for about a 100 ft. or so...That's all I can tell you? It worked for me.
other call BD Monday...Good luck
Old Nov 12, 2006 | 03:44 PM
acook's Avatar
No i dont have the outlook?
Old Nov 12, 2006 | 08:25 PM
HeberRam's Avatar
Did you try driving backwards for about 100' or so applying the brakes?
Old Nov 12, 2006 | 09:05 PM
acook's Avatar
ok so should i clear my dtc's, then start it and drive it back 100 feet, and then hit the brakes?
Old Nov 13, 2006 | 08:40 AM
HeberRam's Avatar
Yes! You may need to go only 60+ try it a couple of times once you have cleared the codes (even if you see no codes) cycle the key a few times after you clear and before you back-up....
Old Nov 14, 2006 | 12:22 AM
acook's Avatar
Ok now whats a cycle, just turning the key on and off a few times, or is it turning it on and waiting a few seconds for everything to shut off like the wait to start light etc...
Old Nov 14, 2006 | 08:42 AM
HeberRam's Avatar
turning it to the run position but don't start. On and off
MrSuzuki
Jun 16, 2009 12:23 AM
boaterman
Oct 15, 2008 10:44 AM
Hillbilly Delux
Mar 20, 2008 05:01 PM
jtskir222
24
Oct 15, 2006 06:48 PM
Mav
Aug 16, 2006 11:20 AM
