towing problems, please help
Old Sep 14, 2006 | 12:09 AM
973604x4's Avatar
Originally Posted by morkable
I only have the normal 602 and 603 which are normal with the bully dog,, and a 700 which is a tranny controller error. I am confused by this boost fooling thing.. can you explain this a bit farther??
thanks in advance
My bullydog doesn't throw any codes?
Old Sep 14, 2006 | 09:43 AM
staarma's Avatar
Boost fooling is when a device clamps the voltage on the MAP sensor so it can't read any higher than let's say 4.68 volts. The ECU looks to the MAP sensor for fueling purposes. If the sensor maxes out on voltage then the ECU sees it as an overboost situation and will back fuel out. You don't want this with a box so the box will clamp that voltage and report it at no more than the 4.68 volts so the ECU is always happy. At that point the box can fuel how much it wants using duration, timing, pressure or whatever. Then you can also add a boost elbow in your case to make more boost with the added fuel from the box or on the 600/610 control it electronically to boost more to match the added fuel without upsetting the ECU.
Old Sep 14, 2006 | 02:35 PM
973604x4's Avatar
good explanation
Old Sep 14, 2006 | 02:56 PM
cquestad's Avatar
abc4yew...
I am always on VACATION!
Old Sep 14, 2006 | 03:38 PM
abc4yew's Avatar
CQ, Me Too when I'm in my truck!...
Boost fooling allows higher than stock boost.....others play with the MAP sensor or other sensors to get higher fueling at lower indicated boost....This is why some people get the DTC "Altitude out of range". ks
DJ Turbo.
Oct 13, 2011 09:11 PM
dieselmx
27
Feb 11, 2009 02:14 PM
SuperiorRam
Mar 15, 2007 03:10 AM
rickkari0304
Apr 1, 2006 04:17 PM
MDW
Oct 3, 2005 09:45 AM
