torque converter Lockup switch problems....
Old Aug 13, 2008 | 11:31 PM
ADDT2TRQUE's Avatar
ok so I just finished wiring up my torque converter lockup switch and when I hit the switch nothing happens. I have it wired as follows...
Battery---fuse---switch----33ohm resistor----#25 wire on C2 module
I checked and rechecked, the circuit is complete and the fuse is good. anybody have any insight on this one?
Old Aug 13, 2008 | 11:40 PM
T & T's Avatar
I haven't seen that scheme. It looks goofy. I used the following wiring and it worked:
ground --switch --- 33ohm resistor and diode----#7 wire on trans harness
different year though.
Old Aug 14, 2008 | 12:02 AM
ADDT2TRQUE's Avatar
when the torque converter locks using the switch are you grounding it out or giving it power to lock it up?
I got the idea of using the #25 pin on the C2 module from this thread https://www.dieseltruckresource.com/...+switch&page=2
Old Aug 14, 2008 | 12:37 AM
chrleb1's Avatar
Grounding the wire.
Old Aug 14, 2008 | 02:34 AM
T & T's Avatar
yea, you need to ground the wire not power it up.
BTW: thanks for the link to the steering column switch. I've been looking for that one. I'll locate my switch this weekend..
Old Aug 14, 2008 | 07:49 AM
TMan's Avatar
On the link, the guy uses a relay, do you need a relay?
Old Aug 14, 2008 | 07:53 AM
jrussell's Avatar
No relay is needed, unless you're doing the steering column switch. Don had to use a relay because the steering column switch was only able to handle very small amounts of voltage.
Old Aug 14, 2008 | 10:48 AM
T & T's Avatar
I thought the relay was to assist with powering up the LED and had nothing to do with voltage through the column (for a steering wheel switch, all that is needed is a ground connection via the switch).
Old Aug 14, 2008 | 10:51 AM
jrussell's Avatar
I could be wrong, but I was pretty sure it was for the micro-switch he used on the column. LED's don't take much power at all, so I don't think a relay would be needed for that.
Old Aug 14, 2008 | 11:18 AM
ADDT2TRQUE's Avatar
well now i feel dumb for powering the wire not grounding it....
thanks guys
Old Aug 14, 2008 | 11:33 AM
T & T's Avatar
I guess I don't understand why you need to worry about a micro switch that provides only a ground connection since it's a signal connection not power.
Old Aug 14, 2008 | 12:18 PM
jrussell's Avatar
Here's a quote from Don's original post...
You would NOT want to use this switch technique using a direct connection as the clockspring probably can not support the direct electrical load.
That ground connection has some amount of voltage running through it. I'm not sure how much, but it's enough that Don felt the need to use a relay.
Old Aug 14, 2008 | 12:26 PM
ADDT2TRQUE's Avatar
well the switch I have is rated at 25amps at 12VDC which is more than enough to handle the load especially since it is being reduced by the 33ohm resistor.
Ok well my switch is still a no go, I hooked it up to ground and when I hit it still no thing happens. Is the #25 wire on the C2 module wrong?? as of now my wiring is as follows.
#25wire----33ohm resistor----switch----ground
Old Aug 14, 2008 | 12:50 PM
Cummins610's Avatar
resistor after switch
Old Aug 14, 2008 | 12:54 PM
ADDT2TRQUE's Avatar
how does it matter where the resistor is located, the switch is just completing a circuit, after the switch is closed then its still just #25 wire to resistor to ground
