Throwing codes and running like crap
Old Mar 12, 2009 | 06:49 PM
Smokeitup's Avatar
Hey all
I am in desperate need of help. Just had the TPS sensor replaced on the truck. When it went in to the garage there were no codes and the only thing happening was a dead peddle. (did have P2022 and P2121 which was the TPS) Get my truck back an hour later and $1100 dollars lighter and the truck is now throwing P0088 and P0251(Fuel rail pressure above max limit and CP3 fuel pump regulator control)
Could they have disconnected something or unpluged something when they installed the new TPS. The truck now has a definate 2nd gen rattle and it runs like a dog. The smarty has been set back to stock setting(not switch 0)
Please help as this is my work truck and I cant afford it to be down to long.
Thanks in advance
Shawn
Old Mar 12, 2009 | 07:40 PM
Smokeitup's Avatar
Can anyone out there help? Someone must have come across the same thing at some point.
Old Mar 12, 2009 | 07:45 PM
lmills's Avatar
Was it running like that when they returned it to you? If so, make them fix it! For the time being, check the FCA connector down on the cp3 pump
Old Mar 12, 2009 | 08:26 PM
Smokeitup's Avatar
Ok I will check that out, and let you know.
Thanks
Old Mar 12, 2009 | 09:59 PM
homewrecker's Avatar
That would sure suck if they disconnected the fca.It will cause a serious rattle because the RP will be at max all the time.
makakoa
Sep 19, 2008 09:24 PM
makakoa
Sep 19, 2008 10:31 AM
tcr
Feb 12, 2008 02:56 PM
cstmfabman
Jun 29, 2007 09:31 PM
serious
Apr 7, 2006 03:39 PM
