thinking about entering local truck and tractor pull
Old Jul 6, 2007 | 08:18 AM
Justin26's Avatar
At the end of the month we are going to have a local truck and tractor pull. I am thinking they are going to have the sleds there to pull. I was wanting to see what the truck would do. What settings do I need to put my bullydog on and also what level on the ez. I have the outlook monitor so I will watch my temps. Should I start off in 4 low or what? Just curious never done it before. Right now I am running in crazy larry and the ez on level 1, getting over 20mpgs.
Old Jul 6, 2007 | 08:29 AM
wap's Avatar
wap
Stock clutch?
Old Jul 6, 2007 | 08:38 AM
Justin26's Avatar
Yep it is stock.
03qclb5spd's Avatar
Originally Posted by wap
Stock clutch?
x2....??
I believe a lot of guys just use 4hi and go in 3rd or perhaps 4th in the manuals. But those guys have much, much stronger than stock clutches to hold the taller gears. If you've got a stock clutch, you better have another truck and trailer there ready to get you home if by chance you toast it.
Old Jul 6, 2007 | 08:46 AM
Justin26's Avatar
Its just an event for charity nothing major just to try and raise money for the fire dept., but if its going to tear the clutch up i will not even do it. I wasnt going to dog the **** out of it to get the fastest time just curious if it would pull it without hurting anything.
Old Jul 6, 2007 | 11:13 AM
jwb600's Avatar
well the sled is not lightweight so if you hook it I would turn the bullydog off and maybe run the ez. its not gonna hold everything turned on hooked to the sled
Old Jul 6, 2007 | 11:46 AM
shineboy2's Avatar
you could always come out of the hole easy in 3rd or 4th low range and if you feel the clutch starting to slip back out of it.
Old Jul 6, 2007 | 03:42 PM
03qclb5spd's Avatar
True. Now I haven't pulled a sled and don't intend to, but on a dirt track how do you tell the difference between tires spinning or the clutch slipping?
Old Jul 6, 2007 | 05:28 PM
dieselram_04's Avatar
the smell! LOL seriously though if your losing speed or not gaining speed and the rpms arre going up your slipping
Old Aug 17, 2007 | 10:31 PM
blaster668's Avatar
My buddy just hooked his '06, with only 15,000 miles on it, up for the first time. He has an Edge Juice w/attitude. His first run was 4lo in 3rd, not enough wheel speed to be competitive but it pulled pretty well. His second run he used 4th and smoked the clutch bad. Hope that little bit of info will help. He intended on replacing the clutch at some point with a good one anyway, this just confirmed that the stock clutch sucks.
ckt_santiago
Dec 26, 2018 03:55 PM
corey88
Oct 1, 2008 08:44 AM
elirandolph
Mar 29, 2008 07:57 PM
CTDPower11
Competition / Pulls / OffRoad
Mar 20, 2007 09:45 AM
HighTen
19
Dec 8, 2004 03:50 PM
