Flux 2.4s ScaryLarry and Ez on stock cp3?
Got my flux 2.4s ordered to go with my S/L (tst turned off) wondering if a EZ would help with my stock cp3 since it adds pressure
Thanks, Charlie
Thanks, Charlie
At least get a Dual rail feed line from Vulcan or II. From what I've read, you will drain you lines even faster with the sticks and the ez. I think those sticks alone would drain the rail. How's that floor it stage 2 holding up to those sticks Rpainter? I want some F-1's bad. What's your rail pressure at WOT?
When I had my 80 hp injectors and S/L on stock cp3 the ez helped get the rail pressure up so it wouldn't drain it as fast but your stock cps has no chance on keeping up. you need to stay around 22k psi to make the best optimum power. no lower than 17k psi
yep good luck with that but I dont think its gonna work well. As most stated above anytime you are going to think injectors and electronic programming your cp3 needs some attention. Why spend alot of money and only go halfway? Just my opinion.
PS I have Scary Larry right now with my injectors...and its nasty power.
bradler
Feb 18, 2009 12:43 PM
OldSmokey
19
Mar 26, 2008 05:11 PM
OldSmokey
18
Jan 18, 2008 09:58 AM
MOJO1
55
Feb 2, 2007 01:01 PM
MoparRiggan
Jan 10, 2007 03:31 PM
