Is there a big fuel line kit for dual CP3 Pumps?
I presently connect through my stock filter housing. From the fuel tank to the stock housing I have a walbro pump (soon I will have two). The lines from the tank to the stock housing are bigger than stock.
Is there a kit for the supply lines from the stock filter housing to the CP3 (I have a twin CP3's)? Also, is there larger line kits that go from the cp3's to the rail itself?
Basically what I am asking is: will larger fuel lines be better from tank to the fuel rail? I understand you can bypass the stock filter housing and connect directly into both cp3's, but I want to keep the stock filter housing and simply switch the lines with larger ones. Would this help fuel flow, power, et cetera -- and is there a kit?
Glacier has one. Its a regular big line with a T in it from what I can see.
http://www.glacierdieselpower.com/pr...pf_id=0307TCP3
Dan Marino
01-05-2009 07:37 AM
adamsmarshall
13
10-07-2008 06:54 PM
Jethro6213
19
07-11-2008 11:59 AM
BADBOWTIE
28
07-14-2007 02:36 PM
powerstrokin03
02-15-2007 04:29 PM
