Modded cp3 or dual cp3's?
I know my rail pressure is low but I need some good info on using a modded cp3 versus the dual cp3 kits. I cannot seem to get any real numbers from anybody tht used a modded cp3 versus stock. I only want about 600 hp so is the dual kit really needed. TIA
Jason
Jason
a modded pump may work for your purposes but, a big reason to go with duals is to reduce the stress on the one pump.
Two pumps will run at 50% keeping the wear down on them and the pressure up but, a single modded would have to work likely closer to 80% or more to do the same thing.
Price is a big factor though too. Modding one is a lot cheaper.
I went with duals to sustain power without any question...(and to grow of course).
A single modded pump like a stage 2 is good up into the 550 area for sustained power. If you just want to blink a dyno screen for a second then you should be able to touch 700hp.
Real world and dyno's numbers are totally different.
700 on a dyno is alot different than 700hp to the ground for 20 or 25 seconds straight.
I went with the stage 2 cp3 to keep costs down. plus pourindiesel made me a deal on it including installation and I couldnt pass it up. BUT if I had the funds I would have the dual pumps. I should dyno soon and hope to be in the 550-600 area. hope that is
Jesse are you going to Dyno at Scheid if you go? Danville is going to have another dyno day in the fall too, and I am sure TST will have one in October like they did last year. Is it me or do you change your signature every hour?
tst is only 50 but its a mustang dyno. they say only a couple guys have dynoed 500 there so I dont know if im gonna keep my spot. my buddy wants to dyno his 01 that he has put money into this year to see what its got
I like change. I dont think those dynos at scheid are very good. they seem old and worn out. I am scheduled at tst for the dyno day. I also talked to danville perf. yesterday actually I may just shoot in there and dyno one day. I want to see what its got now im very interested to know.
That's interesting to know about tst's rollers. I was thinking about scheduling to get on the tst dyno, but knowing that I may stay away. I like the setup at Danville. As for scheid's, isn't one of them dunbar's, or am I mistaken?
what about the ones at scheid? you have been on all them. give us some input
Well that is true I guess. I personally would rather get on a dyno that is accurate. I have read about mustang dynos not being accurate and inconsistent. Of course a dyno number is just that, a number.
