switched power source
Old Nov 11, 2006 | 10:35 PM
caseyclan's Avatar
I am installing a sat radio PNP unit, and want a clean install. I need to find a switched power source to connect the unit to so that I can hide the power cord. is there an easy source available? I noticed a bundle of wireds in the kick panel on the passenger side when I was installing the modulator - is there a switched power wire in that bundle I can use? Thanks for any help provided.
Old Nov 11, 2006 | 10:56 PM
morkable's Avatar
I can speak for all of them but I know that the sirius unit has a converter built in to the lighter adaptor. So if you want to hide the power you will have to build in a lighter socket somewheres. What I am going to do is add a ligher socket on the inside of the dash and splice it into the existing lighter wires
Kevin
Old Nov 12, 2006 | 12:55 AM
XLR8R's Avatar
What is your truck?
Fill out your sig...
Old Nov 12, 2006 | 07:06 AM
MikeyB's Avatar
The cigarette lighter on the dash is switch. That's where I picked up the power for my Sirius sat tuner.
MikeyB
Old Nov 12, 2006 | 08:16 AM
caseyclan's Avatar
Sorry - I have a 2006 QC CTD. Is there a way to get to a switched power source without popping out the bezel? What a PIA that is trying to take all the pieces off before getting to the bezel. I do want to add another socket to hide under the console. Can I use any of the wires in the kick panel?
Old Nov 12, 2006 | 09:20 AM
Dodgezilla's Avatar
It's a lot of pieces but it's really easy. I pulled all that off and installed a REC Nav unit and had it all put back together in a little over an hour. Very easy....
Old Nov 12, 2006 | 10:52 AM
EQUIPPRO's Avatar
Casey, in my last truck I had the Sirius sportster model. I did a install to the roof liner in front of where the overhead console would be. I ran all the wires up the driver side pillar and up above the headliner which makes a nice clean install. It is easy to see and out of the way. However, you do need to go and get another cigarette lighter inlet and splice in behind the existing inlet. The Sirius power cord with the cig lighter has a filter in it. That filter helps eliminate engine noise coming thru. Trust me as I have done 4 installs. I have done 2 Fords and 2 Dodges. I have tried straight wiring into the existing cig lighter power, aux power and switched power. All give a little engine noise which some people can hear and it will drive you nuts. Hope this helps ..... PM me and i will send you a pic of what the install looks like...
IsItFast
Mar 29, 2012 03:41 AM
rainfade
Jul 18, 2009 06:01 AM
papaduck
Jun 21, 2007 08:48 PM
johnny5.9
Apr 6, 2007 08:05 PM
03CTDCO
Feb 28, 2005 05:35 PM
