Sway bar problem?
Sway bar problem?
I installed a 2 in spacer and some DT Pro Fab contorl arms on my truck now the sway bar is hitting the front of the coils. What can I do to fix this problem? Will drop spacers on the sway bar work , what about new end links? Who do you guys recomend getting parts from? What kind of money are we looking at?
Thanks Jason
Thanks Jason
hmmmm.. well i just resently went 4 wheelin in my 06 and didnt dis connect my endlinks and after i was dont one endlink was broken and the other was restin on the coil. after looking at it 4 away i came up with, that some how my sway bar got cought under the coilds and bent the hole sway bar. i took the sway bar off tourched the ends bent them back to where i thought they should be and everything hooked up fine and it works great now. on are trucks the endlinks do sit really close to the coils thow so if its a 1/2 inch away from the coils it probably fine.
I'd like to know the same thing.
You can get blocks from Lorenz Industries for about $65 or longer, and much stronger, endlinks from Carli for about $169. Since you have to buy new links anyway I suggest the longer links.
http://www.dtprofab.com/
0.5" forward
I've been at these to go with the lorenz 2.25 kit when I get it.
0.5" forward
klx650a2
Jan 18, 2009 10:28 AM
tcr
Dec 4, 2007 12:15 PM
Dinner
May 29, 2007 02:02 PM
Robert373
Apr 3, 2007 12:20 PM
