Suspension gurus please chime in
Old Jun 25, 2009 | 12:03 AM
ratsun's Avatar
Hey guys my truck has a 4" Superlift kit in it that the PO put in and I don't know diddly about this stuff.
I would like to lower the rear about 1" or so but looking at it it looks like it might not be to easy due to the air bags.
(If I did this right there is a picture above LOL)
Above the lift blocks there are 2 short 1/2" thick pieces of what looks like leaf spring (these don't show up in the parts list from SL) are these stock or have they been added and can I pull them?
I thought if I removed these it would level out the truck enough but looking at the air bags there is a spacer that the bump stop would normally bolt to that would need shortening also correct, or could I get away with leaving that as is?
Old Jun 25, 2009 | 01:13 AM
Riverbound's Avatar
You can just remove the leaf spring looking spacers. That is what I did on my truck. wonthave any negative effects on the bags.
Old Jun 25, 2009 | 09:52 AM
ratsun's Avatar
Thanks Riverbound, are those stock spacers or were they added by the PO?
Old Jun 25, 2009 | 07:41 PM
crackcorn's Avatar
Those are part of the factory overload springs. You can remove them but it will make your truck sag more with a load. It shouldn't change your ride. I can't see that they flex at all. You will need to buy new U-Bolts! Don't reuse the old ones, they stretch and are not reusable. If you buy the u-bolts at a 4x4 shop check to see what to torque them down too. Recheck the torque after the first 100 miles of driving.
Old Jun 26, 2009 | 10:39 PM
ratsun's Avatar
Okay, will see if I can find some new u-bolts
SPINPOSI
Feb 26, 2019 06:27 AM
CDoskocil9
14
Apr 5, 2007 11:08 PM
runamuk
22
Dec 18, 2006 09:49 AM
Israel Sweeney
33
Oct 17, 2006 06:16 PM
Vic_Ferrari
Feb 21, 2005 06:59 PM
