Surging Trans temp
Old Nov 18, 2007 | 09:28 AM
Sevir's Avatar
Surging Trans temp
for the past few weeks, my trans temp guage will surge (ping out both ways) every now and then. It mainly does it when i am sitting still. it will occationally do it while i am driving. I tried tightening all the fittings in my line where the sensor is. I am thinking its airbound or there is air getting into the line somehow.
Any suggestions?
Old Nov 18, 2007 | 10:29 AM
Foxborough's Avatar
My guess is your power module is going bad. Happened to me last year. Went from Rockford Ill. to Dubuque IA. (2hrs) , kept stopping to check level & feel dipstick ( seeing if 200*) temperature was all over the place 100* to 240*. Every time level good & could hold my hand on dip stick. I put a sticky note over gauge for the rest of trip. Called Dieselmanor and they had to send a new gauge, module and probe since they were calibrated togeather. Been fine ever since.
Old Nov 18, 2007 | 09:21 PM
Sevir's Avatar
Thanks for the help. i figure that was the problem but wanted to make sure before i replaced anything.
Old Nov 19, 2007 | 08:00 AM
jrussell's Avatar
I assume it's an electric gauge that uses an electric sender? If so, be sure to check your ground(s) before replacing anything.
Old Nov 19, 2007 | 11:30 AM
gpshemi's Avatar
My outlook reads like 70 degrees give er take a little all the time no matter what. Buddy thought it might be the Outlook needing an update, but I'm wondering if it isn't more after reading this. Any thoughts?
Old Nov 19, 2007 | 11:43 AM
toyking's Avatar
What are your "normal" driving Temps???
I recently installed Mag-Hytec diff cov & DD Trans Pans...
Trans usually runs 125-140 hotest I've seen is around 150
Rear about the same as above. notice it does run warmer then the trans when
pulling a trailer but never really above 150.
I'd love to know what the temps were b/4 the added fluid of these new pans. My trans is now 9 qt and rear 8 qt. considerably more then stock...
Thanks in advance guys.
Peace
Old Nov 19, 2007 | 12:55 PM
welndmn's Avatar
Check the wire, if its grounding out aginst something, or cut itself on the hole through the firewall it would spike.
Full groud = full peg of the gauge.
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
