Suggestions to help with low end acceleration
Old Feb 26, 2007 | 07:53 PM
03CumminZ4X4's Avatar
Suggestions to help with low end acceleration on 305/555 truck
I have a TST R49 on my 04 305/555 and like it a lot for the most part. I was just wondering what the best box to stack with the TST for improving initial acceleration? I usually run the TST on 3/3 for daily driving and have tried many different settings but none seem to give the truck peppy off idle grunt that I am after. I spoke with TST about going with the early twins program but they didnt seem too keen on that pepping the bottom end up much. My truck runs good after the turbo builds a little boost, but in town it is pretty lifeless. Suggestions welcome. Thanks in advance!
Old Feb 26, 2007 | 08:05 PM
bubba001's Avatar
BullyDog Triple Dog
I just replaced my Bank's Six Gun with Speed Loader with the Triple Dog. I enabled the low end enhancements, and I can't believe the difference. The throttle response is so superior, and you can definitely stack that, as it is a downloader.
Old Feb 26, 2007 | 08:15 PM
stang's Avatar
add a Dr Performance Stage III run it on tow mode that will help the bottom end
Old Feb 26, 2007 | 08:22 PM
Mega Bass's Avatar
I just did the same thing with my Triple Dog. Definitely gave it more low end grunt. I also put on the outlook and it shows EG temps, tranny temp, boost and all sorts of other things. Very easy to install.
Old Feb 27, 2007 | 03:18 AM
tristan21's Avatar
From what ive heard the smarty had the most power off the line when stacked of all the downloaders.
Old Feb 27, 2007 | 09:10 AM
goodeyesniper75's Avatar
i really like the bully dog for low end huge difference over the 6 gun.
Old Feb 27, 2007 | 09:31 AM
tcr's Avatar
tcr
BDDLs ARE NOT the answer on the 305/555 engines, the Banks 6gun/spd ldr will blow the doors off the BDDL only on the SO/HO 2003-04 models. I would say for low end on the 555 engine get a SmartyCR or the Diablo Predator. Oh, and a new tranny because you'll need it
Sorry Goodeye, I think we posted at the same time, I'm not contradicting you. I'm just speaking from experience w/ the two on the dyno on my truck. I really liked my banks until it came time for more power
Old Feb 27, 2007 | 09:35 AM
really....my 6 gun/speed loader was terrible, almost no difference to me but the bddl gave me great low end power that lasted all the way to red line.....
Old Feb 27, 2007 | 09:42 AM
35" 05''s Avatar
sell your tst and get a smaty or bddl and get a quad xzt or other pressure box to go with it. Unbelievable low end!
Old Feb 27, 2007 | 09:47 AM
abc4yew's Avatar
On an 03-04 the Smarty TST combo is hard to beat especially if you have the rail pressure upgraded TST. With Smarty you can have 4 different levels of torque management to keep your drive line in good shape. On an 04.5 to 06 Scary Larry (no longer available) outperforms the Smarty. If you want to continue to use your TST and you should then Smarty is the way to go....but you will run out of fuel if you run the TST above 3/3. Run the TST on 6degrees auto max with the Smarty timing on. ks
Old Feb 27, 2007 | 11:10 AM
cquestad's Avatar
Ditto...don't ask me why I know.
Old Feb 27, 2007 | 04:05 PM
Thanks for all the replys. I have not been on here in a while. I guess the days of the MP8 or the EZ stacked with the TST are long gone then?
Old Feb 27, 2007 | 04:12 PM
cquestad's Avatar
Nope...they only got better...Smarty w/ TST and MP-8.
Old Feb 27, 2007 | 05:28 PM
If you had to chose one or the other to stack with the TST which one would you choose, the MP8 or the Smarty, and why? Thanks.
Tiara3100
Mar 4, 2011 07:01 AM
LanceD
Oct 5, 2010 05:00 AM
piperca
14
Apr 29, 2008 01:00 AM
ImagesThatSing
Jul 27, 2006 05:41 PM
Dodge@KY1997
Apr 30, 2006 01:01 PM
