stock muffler removal?
Old Oct 18, 2007 | 08:24 PM
BG05TD's Avatar
anybody out there have any tip on removing the stock mufler? im talkin about just the muffler...i got the muffler eliminator and man... that thing is a beast to get off! thanks for the help
Old Oct 18, 2007 | 08:27 PM
t-boe's Avatar
Cut off wheel worked for me.
Old Oct 18, 2007 | 08:29 PM
CD in NM's Avatar
I cut several slits with a grinder on the flanges, then bent them back away from the other pipes. It is a pain to expand otherwise. You can heat the flanges with a torch and rock back and forth to get past the clamp crimp too. That seemed like too much hastle. You can always re-install the muffler after cutting the slits if you decided to put it back on. Just cut slightly past the clamp crimps so the metal will move out and free the crimps.
CD
Old Oct 18, 2007 | 09:03 PM
DieselBoy20's Avatar
Saw Zall works good too....i used a wrap around and made a chalk line and cut my exhaust pipe with a plasma cutter, worked awesome....my 07' 5.9L is straight piped and loud as hell.
Old Oct 19, 2007 | 10:15 AM
levigarrett76's Avatar
sawzall/bandsaw/angle grinder/torch/plasma/hacksaw/zizwheel
i prefer the sawzall method
Old Oct 22, 2007 | 10:05 PM
BG05TD's Avatar
thanks guys.... used sawzall then grinder...i'm never puttin the muffler on again anyway! took about 20 mins and sounds about 100x better
Clayton Poth
Apr 18, 2008 11:56 AM
sandpuller2004
15
Dec 17, 2004 03:02 PM
FarmBoss
Nov 10, 2004 04:24 PM
commonrail
Oct 22, 2004 07:47 PM
w4xtc
24
May 5, 2003 04:36 PM
