Steel wheels and 315s
Old Mar 10, 2008 | 01:04 PM
Dodgezilla's Avatar
Can you run 315s on the steel ST wheels?
Old Mar 10, 2008 | 01:18 PM
Lsufan78's Avatar
i don't see why not????
Old Mar 10, 2008 | 01:20 PM
matego's Avatar
madhat's monkey boy...
The steel wheels are only 7.5" wide.... correct? I am pretty sure that is what my set says on them. That is a little narrow to run 315's from what all the tire sites say.
Old Mar 10, 2008 | 03:03 PM
chipmonk's Avatar
i see trucks running that set-up every day, around here.
Old Mar 10, 2008 | 03:34 PM
rootercycles's Avatar
I too have 7.5 wheels and was told that I could run up to 285's. I want to run taller tires, but don't think I have the rim width to go any bigger
Old Mar 10, 2008 | 04:30 PM
03whitedually's Avatar
hey dodgezilla are you still pulling a heavy trailer with the new truck? if so please tell me how if behaves with single rear wheels. I pull and 29' cruiser and worry about sway
Old Mar 10, 2008 | 04:51 PM
Dodgezilla's Avatar
I had an 03 SRW w/ 315s and it towed just fine. It did sway a bit more than the dually but the sway control for the trailer tongue helped alot. The 315s did not squat at all even when the trailer was loaded. That was a 3500 though whereas my new truck is a 2500. I may get some airbags eventually.....
Old Mar 11, 2008 | 07:34 AM
jrsmokestacks's Avatar
Thares a ton of duallys running 315's on the 6" wheels. I ran 315's on a 7" srw truck and didnt like the amount of sway towing my 10K enclosed.
SmokeyBear
34
May 28, 2011 11:42 AM
D45
21
Jun 2, 2008 03:37 PM
VikingDiesel
33
May 16, 2006 09:25 AM
Dodgezilla
Jun 25, 2005 11:29 AM
2k1yzfr1
Nov 29, 2004 12:29 PM
