Snow Stage 3 Water Meth kit
Old Feb 27, 2006 | 09:16 PM
Syndicate's Avatar
has anyone used this system???? How well does it work when towing? How much juice does it go through on average per mile? Is that 8 Gal tank enough or should I just get a 25 gal fuel cell and use that.
Old Feb 27, 2006 | 09:42 PM
AK RAM's Avatar
Dude, with all the bombing parts you have been asking about lately, you must have gotten one FAT tax refund!
Old Feb 27, 2006 | 10:13 PM
Syndicate's Avatar
just tryin to figure out what Im doin. I dont want to have to buy things then end up not usin stuff thats not goin to be a part of my setup. Id rather ask lots of questions and buy only what I need and get stuff havin a pretty good idea of how it will work with the other parts Im goin to run.
Old Feb 27, 2006 | 10:28 PM
Syndicate's Avatar
Im thinkin right now of runnin the following.
Rasp pump - to be done
DTT Trans -TBD
Honed injectors - already done
AFE stg 1-already done
Quad Xzilla- Might uprage it to RACE version
4'' exh -done
SPS 62 -TBD
Snow Water Meth stage 3 kit-TBD
I am thinkin this will provide me the FUN factor Im lookin for on the street. Dyo over 500HP and Tow my 10 000lb 24' enclosed pretty well with the box turned down or off.
Old Feb 27, 2006 | 11:59 PM
AK RAM's Avatar
That does look like a good list and should do you proud. Definitely upgrade to the Quad Race.
The Snow Stage 3 is kind of new and I don’t know much about it, but given the quality of their Stage 2 kit, which I have, I would think it will be a nice addition, and keep close to all 500HP useable when towing. W/M can lower EGTs a lot in addition to making more power. If you want to use it for every day driving and towing, go big with the tank. The little tank that comes with it gets me 2 passes down the 1/4 mile. That's it. Others that use it for towing can give you a better idea.
With your injectors, SPS62, Quad Race, and water/meth, I bet it will dyno closer to 550HP. I have seen a truck in that same configuration do 505hp without water/meth.
Water/meth takes time to work. To get the power it is making for you show up on the dyno, I would set the 1st stage to come in at 10 lbs of boost or less (whatever you can get away with without pinging), the 2nd right after (sooner the better), same with the 3rd, and try to load the turbo to get the meth going at the same instant the run starts. If not, the run will be over before the water/meth kicks in good. A good 50/50 mix will make 75hp.
Old Feb 28, 2006 | 12:32 AM
Syndicate's Avatar
Thanks a bunch for the info. From now on if I want to know anything Im just goin to ask you first.LOL. Your responses are very helpful and detailed which I think is great. Not to mention your not just spittin an opinion at me.Your talkin about what you have seen first hand.That is the info we are all lookin for on here.
Old Feb 28, 2006 | 01:36 AM
AK RAM's Avatar
This time of year I have no life. If you were stuck in this winter wasteland for 8 months out of the year , you would probably spend a lot more time here than you should too. Spend enough time here and regardless how clueless you are, you are bound to learn a thing or two….that would be me.
Old Feb 28, 2006 | 07:31 AM
PanteraGSTK's Avatar
Any time you can learn about trucks instead of being board is time well spent. I'm amazed at how much I've learned since I joined. I'm done.
Old Feb 28, 2006 | 07:49 AM
MikeyB's Avatar
BTW, there's a pretty good writeup in the latest edition of Diesel Power magazine on the Snow Performance W/M injection system.
MikeyB
Old Feb 28, 2006 | 09:28 AM
Dodgezilla's Avatar
Hmmmmmm................................ Did I say I was done??
Old Feb 28, 2006 | 10:40 AM
BigBlue's Avatar
Just be careful or you might end up like me with no life, single, and broke because your passion for your truck overtakes everything else in life.
973604x4
44
Mar 9, 2007 01:29 AM
6006spd
Aug 2, 2006 10:47 AM
Hoss
Dec 10, 2005 02:30 AM
OT-OF-Here
14
Oct 18, 2005 12:28 AM
