Smoke Switch for TST
Old Jul 22, 2007 | 08:41 PM
  #46
adventuris's Avatar
when tie into map harnesss , where do i tie the swicth in at i have a quad boost fooler and and predator puck do i put the switch at the map plug that plugs into those first or put it after the puck and fooler .
Old Jul 23, 2007 | 01:07 AM
  #47
qzilla's Avatar
You should plug your puck into the map sensor, then the boost fooler. Now you want to do the switch to the Puck harness. Basically you are giving a false reading to the Puck but, the boost fooler will still work and tell the ECM that the boost is ok.
It may not work on the PUCK? It sounds like at higher boost levels the puck does not do too much anyhow??
I am not even sure which boxes it is going to work on. I just told a couple of guys a long time ago how to do it on our modules and here we are!!!!
Old Jul 24, 2007 | 09:43 PM
  #48
04DEEZELRAM's Avatar
So if i have boost fooler, and no chip, where do i hook the switch up, between the sensor and boost fooler, or the fooler and the wires running back to the ECM.
Old Jul 24, 2007 | 10:01 PM
  #49
OldSmokey's Avatar
I hooked into the map harness that goes into the sensor on the top of the motor.
Old Jul 24, 2007 | 11:18 PM
  #50
qzilla's Avatar
If you have no chip then the smoke switch will not work. You are not tricking the ECM, you are tricking the power module itself into giving full fuel off idle.
Old Nov 19, 2007 | 09:50 PM
  #51
jasonstacked06's Avatar
ok sorry but im confused do you have to have a programmer for this to work? thanks
Old Nov 19, 2007 | 09:54 PM
  #52
sorry missed the post right above me
Old Nov 19, 2007 | 09:55 PM
  #53
which programmer is needed to do this switch ?
Old Nov 19, 2007 | 10:15 PM
  #54
na4now's Avatar
TST or Edge, ...and maybe QZ?
Old Nov 20, 2007 | 02:17 AM
  #55
im sorry but im new whats TST ? sorry i knwo its a dumb question
mjpalmer
May 19, 2005 11:34 AM
WhiteSport600
Dec 23, 2004 09:59 AM
BCobb
Jul 11, 2004 01:49 PM
Zino
Aug 15, 2003 10:14 PM
