Smarty TST pm 37 stack
Old Nov 21, 2007 | 10:21 PM
Topper's Avatar
Hey guys,
Like the title states I'm stacking a Smarty with my TST and was wondering what setting you guys are running. I have my Smarty on sw3 and I run me TST @ 6hp and 4tq. I did try it (the Smarty)on higher setting but have had alot of surging. I realized tonight that I'm running the Smarty on the odd setting and I think I should be running it on the even settings. I think the TST adds timing.
Anyways, any help with the settings would be great!
Thanks,
Topper
Old Nov 21, 2007 | 10:53 PM
soulezoo's Avatar
DTR 1st Sergeant
Try running the smarty on level 8 and tst on 3/3 and see what happens..
Old Nov 22, 2007 | 12:18 AM
bwarning01's Avatar
I run the SMARTY on sw9 and do the adjusting with the TST. The TST is a fuel only box and does not add any timing.
Old Nov 22, 2007 | 12:47 AM
RDyson's Avatar
On the 3rd gens, the R37 TST does timing all the time per the tech at TST. You should run the Smarty on the even #'s and play with the TST for extra umph.
Randy
Old Nov 22, 2007 | 02:46 AM
cquestad's Avatar
There is lots of ways to skin the cat. With the 37...I guess you can't adjust the timing...so...
Try sw4 or sw6 and TST 4-2 or 5-2 to max out the stock CP3. Better have a lift pump.
Old Nov 22, 2007 | 05:01 PM
Topper's Avatar
Thanks for all the input! I'll be trying some of your suggestions in the morning.
Thanks again,
Topper
Old Nov 22, 2007 | 06:18 PM
jwb600's Avatar
I ran that stack for a little bit and ended up taking it off. the tst/smarty stack made 490 with the smarty on 8 and tst on 5x2 I believe. and it was popping way up in the rpm.
Topper
Mar 3, 2008 10:17 AM
LooseBoltsRob
17
Jun 10, 2007 08:52 PM
smoky beast
28
Oct 13, 2006 01:15 PM
cummnz4x4pwr
Jul 30, 2006 01:37 PM
mjpalmer
May 19, 2005 11:34 AM
