smarty question
But it cant fix them to what "should" be there... it has no way of knowing.. it just goes off what it saw when first installed.... Just like if you have a Jr, take it off for a OEM reflash, and put it back on the keycount will be much different, but will be where Dodge thinks it should be.
Do your self a favor and get a BF if you are gonna run your puck. You will have a problem with Limp mode and overboost condition TRUST ME
Your going to be over 500 in no time
Bob is a great guy you made the rite decision
Chris
Grant your gonna fall in love with the Smarty
Chris
Chris
Instead of getting a new one the company where I bought it gave me store credit. I used the credit to buy a quadzilla xzillaraider.
Chris
Good to know.
I had the TST before Smarty and was told that it did boost fooling. From reading it does not specify the 44lb level either just says something about using aftermarket turbo software to allow higher boost levels. My TST provides fooling for my config. I have never needed over 40 lbs with my current setup. I will definately make not of 44lb as the MAX for Smarty fooling.
Thanks for the correction..
skydiver41
Mar 23, 2012 08:51 AM
stock03
34
Apr 21, 2011 07:40 AM
jmccart
Nov 22, 2007 07:43 PM
Mike Holmen
May 21, 2007 10:21 PM
