CFM+ and SC Flashpaq
Old Feb 29, 2008 | 08:34 PM
js091899's Avatar
Going with the CFM and I am thinking of the grid heater delete while I am there.....I live in Florida and I can't believe I reaaly need this but to be honest I don't know. Looking at other post and pictures it looks fairly restrictive but does anyone have a definite this is good or bad????
Old Feb 29, 2008 | 10:05 PM
rip 112's Avatar
You should have no issues eliminating your grid heaters beside the CEL coming on possibly. This happens to some, not everyone.
Old Feb 29, 2008 | 11:25 PM
Billm2004's Avatar
Hey where in FL are you, im in miami. i have heard there is a way to keep the CEL off when you take out the grid. im thinking of doing it too. here in FL you dont need it, i have seen people in 20* weather with no grid start fine.
Old Mar 1, 2008 | 08:33 PM
js091899's Avatar
Jax here....if its get to 20 I don't go out much....the Sc should be able to clear any codes I might get????
ps I can't wiat to hear the crap I get for not liking the cold.....
parts will be here Tuesday....need to make my mind up about the grid.
Old Mar 1, 2008 | 09:26 PM
carl48's Avatar
take the grid out it does not help starting it is to reduce white smoke on start up. on 06's the ecm monitors the relay controll current when the heater's are called for if you remove the relay just place a 16 ohm 10 watt resistor across the two small black wires that use to activate the relay i am not positive the 04.5 do this also but i think they do
strucksvt
Mar 15, 2008 08:56 PM
ddestruel
Dec 25, 2007 06:28 PM
megafast
Apr 24, 2007 07:29 AM
