Smarty Hot Beta tests
Old May 1, 2007 | 10:03 AM
  #121
Sloverado's Avatar
I put a pressure box on mine today. Didn't set any codes and I will be dynoing it this weekend.
Old May 1, 2007 | 12:15 PM
  #122
tcr's Avatar
tcr
Wow, Even level one is BAD @#*!! So much stronger than the previous versions. I've tried it w/ Quad on 60hp, and on the higher levels it is AWESOME! I'm kinda scared to go much further.
Marco,
Is there any chance this will be available in different TM versions??? How about a speed limiter removal?
Old May 1, 2007 | 12:29 PM
  #123
dodgezilla04's Avatar
uh, i stacked the quad with mine on level 9, only went to the first 60hp setting and i just wet myself. so be careful. i did NOT hear any timing rattle when stacking, but was worried about pressure.
this thing just gets better
Old May 1, 2007 | 11:52 PM
  #124
gus's 03's Avatar
MARCO: pleas dont change it!
i tested it with cruse control tonight, up and down holls @ 60, 65, 70, 75 and was perfectly manered no surging.
steady speed 75mph level ground, 6psi 600*. fuel economy is looking promising if i can keep my foot out of it.
my take on the throttle sensitivity. its not bad enough to keep me from using as a dayly driver. i just have to stay a little more alert in rush hour grid lock. im willing to pay to play. and i think it might be enough to scare the he!! out of some one who realy shuldnt be running it. and with the low end that it has im sure this will destroy an non built auto instantly, and from my experiance, thats what 90% of the yuppie kids that have one drive.
heck this versions wild enough, id say that you almost ought to intentionaly make it leave traces in the ecm so people dont try to blame it on dodge and warrenty parts because of it! but thats just my 2.cents.
Old May 2, 2007 | 07:53 AM
  #125
tcr's Avatar
tcr
"its not bad enough to keep me from using as a dayly driver. i just have to stay a little more alert in rush hour grid lock."
Hey Gus, no offence intended, but this isn't the brightest idea I've heard in awhile. Obviously you don't drive in a city full of idiots like I do. You want a daily driving program that you have to stay more alert to drive??? When it's probably possible to smooth out the fueling and acheive the same HP and pull just as hard? I think options will change when the majority gets to use this program, especially the auto guys.
Old May 2, 2007 | 10:26 AM
  #126
Marco's Avatar
gus's 03 & tcr,
this is as close as it can get to a perfect example!
Each one tells me the exact opposite of the other!
You won't believe how many times that happens! What works for one guy does not for the next...
WHOM of you two do I listen to?
LOL... To be or not to be....
I guess the one size fits all tool simply does not exist.
Marco
Old May 2, 2007 | 10:42 AM
  #127
RyeThomas's Avatar
Winner winner chicken dinner!
You cant please everyone thats for sure. I like the program the way it is and think its far more driveable then say a Bullydog with Torque Management delete.
Im using it as my everyday program, and I dont see any issues with it. But again thats just me.
Old May 2, 2007 | 10:43 AM
  #128
morkable's Avatar
I think that if the new software is too wild for someone they can go to one of the milder tq management softwares. Hence all the options
Kevin
Old May 2, 2007 | 10:47 AM
  #129
tcr's Avatar
tcr
Kevin
EXACTLY, if a Mod TM HOT version will be available, that would be my perfect world. Will this be the case? Or will it be like the Wild and only have 1 TM option.
Marco, Don't listen to me, just listen to the majority once it hits the public. Fair enough?
Old May 2, 2007 | 04:12 PM
  #130
JThiessen's Avatar
Well, based on TCR's zip code - he in fact does drive in a city full of idiots! But then, I bet if Marco asked, everyone drives with idiots.
Old May 2, 2007 | 04:15 PM
  #131
ooooh, careful, calling all those folks in austin idiots? that may cause a riot here. being just across the ferry J, you see your share on 99, and I5
Old May 2, 2007 | 06:02 PM
  #132
JThiessen's Avatar
Yeah, it was tongue in cheek though! BUT...I meant Gus's 03 (sorry TCR - I do know those on-ramps you guys have down there scare the pants off me...........you got about 50 yards to merge into 80mph traffic in a lot of spots!).
Old May 2, 2007 | 07:51 PM
  #133
gus's 03's Avatar
yep i5 between everett and seattle, been in the top 10 worst trafic in the nation for over a decade...
and ill prob get my self killed for the next coment..... i have to merge onto the boeing freeway, and thoes are the worst of the idiots!
as far as the throtle response/tq managment... im going to stick to my guns. i say keep it this way, atleast for any " hot " versions.
marco has stated this is the basis on wich future software will come from. ie: milder versions etc. im sure there will be versions to apease the mas public. i guess " stay alert" want the right wording... i guess what i shulda said is " in trafic i just need to drive like my wife is with me" does that get the point across better. its controlable, i have had no problem so far in the 6+ hours of stop and go gridlock that ive seen this week, i about crushed a rice rocket, but thats no fault of the smarty.. (he prob wont drive at night w/ his headlights off, and sit in a blind spot next to a lifted truck)
Old May 2, 2007 | 08:18 PM
  #134
Morse's Avatar
I ran a 13.35 in an 06 2wd 2500 at the NHRDA meet at Moroso this past weekend with the new 60 hp program. I'll turn it up at the track as soon as I take care of some traction issues.. It has a PS62-14 and Dynomite Diesel 90 hp injectors.
Old May 2, 2007 | 08:20 PM
  #135
Morse's Avatar
On the dyno mine showed just over 3900 rpm..
