Smarty DL's, why 2 of every version for 06?
Probably a stupid question, so I don't want to but Madselectronics with this one. Why are there 2 DL's that have the same number versions (read outs on the Smarty itself) but one ends in: A36 and the other ends in A47?
Anyone know the diff. one these? I have used the A36 of ever version I have tried.
Thanx.
Thanx.
Thanx.
Thanx.
It is my understanding the 36 stands for 2003 thru 2006 models.
The 47 stands for 2004 thru 2007 models.
Question is, if you have a 2004, 2005, or 2006 model which file do you choose?
Maybe someone with more knowledge will chime in.
Larry
Larry
Larry
That is correct....they can't fit all the files associated with 2003-2007 on one software load into Smarty's memory....so they split 03-06 and 04-07....
04,05,06 doesnt matter, it's the same software so you can use either....
Thanks, another little mystery out of the way
Larry
