Why is my '01 24V smoking more every day?
Old May 18, 2004 | 05:57 PM
243's Avatar
243
Why is my '01 24V smoking more every day? *Update*
I bought the truck with 56K miles in Dec. 2002 and it now has 89K miles. I've noticed that it seems sluggish and it smokes much more now than it did when I bought it. I am referring two 2nd and 3rd gear pulls at low rpm.
It is stock as far as I know, I have not pulled an injector to see if the previous owner may have installed 275 injectors but it is possible.
I have checked the intercooler hoses but not recently and temporarily removed the air filter to see if that made a difference.
What else should I look for?
Old May 18, 2004 | 06:23 PM
BigBlue's Avatar
What's the fuel pressure? Do you have any codes? Sounds like your not getting engouh air into the engine. Check for leaks in the pipes and boots on the intercooler.
Old May 18, 2004 | 06:58 PM
243's Avatar
243
It has been about a year but the last time I checked the intercooler hoses and lift pump pressure they were fine. I can't tell you the exact pressure though.
Can I extract the codes without a scan tool?
Old May 18, 2004 | 07:09 PM
BigBlue's Avatar
Ya. Just turn the key on/off three times and leave it on the third time and you should see the codes come up in the odometer screen. I'd check the intercooler boots. Smoke means not enough air to burn all the fuel being injected.
Old May 18, 2004 | 07:30 PM
243's Avatar
243
No codes, I believe it first displayed P ECU and then PCU DONE.
The lift pump pressure is 13 psi when bumping the switch and 12 psi at idle. I believe the port at the back of the filter housing yields actual lift pump pressure, correct?
I will check cruise and WOT lift pump pressure later tonight.
What is the best method for checking the boots?
Old May 18, 2004 | 08:26 PM
blackjack's Avatar
there are no mods listed in your sig so assuming that you do not have a box malfunctioning? also assuming that the smoke you are talking about is black smoke indicating an overfueling condition. White or gray smoke is a different problem all together.possibly the good news here is that if you have no mods chances are this problem will be covered under warranty.
Old May 18, 2004 | 10:04 PM
243's Avatar
243
Blackjack, no mods and stock as far as I know and it's black smoke.
Old May 18, 2004 | 10:36 PM
HOHN's Avatar
-- low fuel pressure
-- weak VP
-- dirty IAT sensor
-- MAP voltage artificially high
-- leaky injector
-- intercooler/boost leak
That's what I would check first. Sounds like you've ruled out a bunch.
Justin
Old May 19, 2004 | 07:09 AM
243's Avatar
243
HOHN,
1. low fuel pressure (lift pump pressure?)
2. weak VP (how do I determine if the pump is weak?)
3. dirty IAT sensor (will clean this morning and check lift pump pressure at WOT)
4. MAP (is this a replace or reset sensor?)
5. leaky injector (I think this is a real possibility, on this truck)
6. I will check these today
Old May 19, 2004 | 07:16 AM
RustyJC's Avatar
A few other possibilities:
Dirty air filter
Dirty intercooler (hotter charge = lower air density = more smoke)
Hotter weather
Old May 19, 2004 | 07:22 AM
Palmetto_kid's Avatar
yes. But the Most popular place to check is the port @ the VP. Simply because it will show you how much pressure you have at the inj. pump. Low pressures seen here can also indicate a very dirty Fuel Filter.
My '01's lower boots were cut by the fender sheet metal. I dont see how they fit that intercooler in there. Both the driver and passenger side fenders had cut into the boot. I replaced both with Piers Boots, and let me tell you! they were a royal pain in the butt toget on. I bent the fender out with some channel locks to keep it from rubbing.
where are you at in H-Town? I work in Sugarland.
Old May 19, 2004 | 07:57 AM
243's Avatar
243
Hey Rusty, the truck hasn't had a bath in a long while, I'll degrease the front end and take it to the carwash. There is no filter in the box temporarily.
kid...I checked for cuts in the boots and tightened all of them, the passenger side lower required quite a few turns on the nut. No but I'm not completely sure they are
Pressure into the fuel filter is 14 psi idle, 12 psi cruising and 9 psi at WOT. I will go back out this morning and move the test guage to the pump.
Old May 19, 2004 | 09:07 AM
DRD's Avatar
DRD
While your moving gauges around I'd check boost as well....
Old May 19, 2004 | 09:42 AM
243's Avatar
243
DRD, I don't have a boost guage and at the moment no plans to buy one....unemployed temporarily but have a little time to tinker
Old May 19, 2004 | 11:36 AM
DRD's Avatar
DRD
I thought you had a master gauge you were checking fuel pressure etc with.....?
