Smarty and Banks
Old Mar 26, 2008 | 11:29 AM
zack birge's Avatar
Cool Smarty and Banks
Can i run a smarty with my banks six gun??? If so what setting should i use them together with?
Also can i use a smarty jr. with my banks??? Same^^^^.
Old Mar 26, 2008 | 11:46 AM
soulezoo's Avatar
DTR 1st Sergeant
The answer is yes to both. You can run any and all settings... but...
Banks adds timing and Smarty can add timing. If you run the smarty on the odd numbered sw's (1,3,5,7,9) they add timing and therefore do not turn Banks past 3. If you run even numbered sw's (2,4,6,8) you can run the Banks all the way to 6.
Regardless of what you do, realize the Banks will hold you back at a certain level. It won't let you pass certain thresholds that are the built in safties. Like 40 psi boost for instance.
Old Mar 26, 2008 | 11:51 AM
zack birge's Avatar
Im probably going to try a guys smarty jr. here in town soon and i was just wondering how to do it without causing any problems!
Old Mar 26, 2008 | 11:59 AM
zack birge's Avatar
What do i need if i end up buying a smarty???
Old Mar 26, 2008 | 12:07 PM
soulezoo's Avatar
DTR 1st Sergeant
No problems, download and go. Don't forget to return to stock before giving your friend back his Smarty jr...
Old Mar 26, 2008 | 12:08 PM
zack birge's Avatar
Got cha! Am i needing anything to besides my rebuilt tranny to run the smarty? Not really wanting to put much more money into it than i already have! Thx
Old Mar 26, 2008 | 12:15 PM
soulezoo's Avatar
DTR 1st Sergeant
Well the tranny is a must if you want to use smarty on upper levels... after that, it is just supporting mods that you don't have to have to run smarty but may want to do to take advange of the smarty potential. After the tranny work, you can run the regular smarty tunes and really not have to do anything else but watch your gauges. But you will... I promise.
Old Mar 26, 2008 | 12:21 PM
tristan21's Avatar
........alot of will power to keep you on the lower levels.
Old Mar 26, 2008 | 12:30 PM
zack birge's Avatar
Well i already have got my tranny rebuilt and a billet input shaft and flexplate, and had my vb modded and a tc put in! Should i be ok? I think i am going to end up buying one?
Old Mar 26, 2008 | 12:33 PM
soulezoo's Avatar
DTR 1st Sergeant
You will be ok with that... and I am sure you will end up getting a smarty too.
Old Mar 26, 2008 | 12:40 PM
zack birge's Avatar
Which do ya think would be better the smarty or the jr.?
Old Mar 26, 2008 | 01:00 PM
rip 112's Avatar
The Smarty SR, mainly because 100hp just isn't enough for me.
And truthfully, just ditch the Banks, its not gonna help, get you some gauges if you don't have some and make you some money back on that banks. I used to run the 6-gun and though it was excellent for towing, it just didn't do the trick. Sold it to another guy who as far as i know still has it and is satisfied with it for what it is alone.
Old Mar 26, 2008 | 09:27 PM
zack birge's Avatar
Thats true! I am officially getting one now! lol Is it best to order it through DTR? Is the smarty better for towing?
Old Mar 27, 2008 | 12:26 AM
rip 112's Avatar
Yes ordering through DTR will help support the forums.
Old Mar 27, 2008 | 02:20 AM
Snapoff's Avatar
zack birge,
Prepare for real power!
Ditch the Bonks and download a beta file from Mad's site.
Add a turbo and valve springs then you can install the TNT program...230 Hp!
There is nothing like a full tilt Dodge!
In case you haven't figured it out....Your an addict!
Most guys wait till the warranty ink dries before modding their truck!
Warning!....Black smoke is addictive.....and may cause drive train Cancer!
Check my signature if you feel bad about what you've spent in the last year!
Most of it has been done twice.
