Smarty 4.11???
Smarty 4.11???
I'm still using 4.11 and love it. I really want to send her in to Bob for the POD upgrade but am worried that the new program won't be as powerful?? Should I just send her in anyways??? How is everyone liking the 4.01A??? Thanks guys...
On the TNT, what level would have the same characteristics as the 4.11 on SW#9? I run SW#9 with the 4.11 with no problems now and don't want to go to a lesser HP SW if possible. Just don't want to trash my stock injectors..
You would have to play with the settings but even the Revo will be better than the 4:11 in my opinon. You can go sw9 or sw7 and play with the settings and find what works for you, You will like Revo better over the 4:11 because of the numerous setting for timing, pressure and other stuff. I say switch
I was like you and didn't want to switch from 4.11 to the Revo tune either,and when I did at first I didnt like the Revo, but after I started to play with the settings I changed my mind...Go for it.
what is the POD upgrade? the TNT program you guys are talking about is that the TNT or the TNT-R. I tried the TNT and the Beta 4.4 and it felt like to me the Beta 4.4 was more powerful and it also gave me more boost and lower egts
IMO, 411 has the best driving characteristics with an auto, and it is much stronger than the standard Revo. I still, have not had any luck running the TNT without issues, "dodgediesel" has an 07, so he will be fine with the TNT.
The TNT is absolutely stronger than the 411, no aurgument there, but I did not like the way it "hung" in each gear, before shifting, and at idle the exhaust would darn near bring tears to my eyes.
dodgediesel, do not discard the 411 from your Smarty file, you may want to go back. And I believe you can send it to Bob with the 411, and thats what you will get back.
Jess
Jess
POD upgrade stands for "Power On Demand". 100 levels of adjustment on the fly. Check it out @www.madselectronics.com
so when you pick a power level between 0-99 how does say picking 60 do if i'm on level 9 on my smarty. does that detune it to 60% of level 9 for better economy? and what happens if i choose 0, is that stock?
Jess
Jess
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
CTD_Neil
02-23-2006 09:27 PM
