Smarty
Old Jan 25, 2007 | 02:00 PM
chrigu's Avatar
Smarty
hi
i have the smarty today now i make ecm update.
now the voltage going up to 14,9 volt on idle.
is normal?
weh have 23 C Fahrenheit outdoor.
thanks
chris
Old Jan 25, 2007 | 03:09 PM
HappyGA's Avatar
should be fine. Just your truck charging your batteries after the grid heater is kicking off, and from cranking the truck...
Old Jan 25, 2007 | 06:08 PM
chrigu's Avatar
hi the grid heater have 2 min? ist this correct?
i have approx 2 min 13-14,9 volts an then going to 14,8 volts constantly.
chris
Old Jan 25, 2007 | 06:10 PM
P.J's Avatar
P.J
I would call that normal too. You should be able to see the headlights dimming (if on) when the heater cycles also.
Old Jan 25, 2007 | 06:12 PM
chrigu's Avatar
yes the heads lights dimming approx 2 min.
Old Jan 25, 2007 | 11:23 PM
chrigu's Avatar
the maximum to charge e batterie actual 2,45 for one cell.
we have 6 cell 6x2.45 V = 14.7 V
is 14.9 not to high? ore normal with this outdoor temperatur?
chris
Old Jan 26, 2007 | 12:33 AM
nebuniRAM's Avatar
Sounds normal to me
Old Jan 26, 2007 | 04:14 AM
chrigu's Avatar
ok
i think also.
thanks
chris
Old Jan 26, 2007 | 11:33 AM
chrigu's Avatar
today i have 15 Volt.
Old Jan 26, 2007 | 12:03 PM
MikeyB's Avatar
I would verify what you're actually seeing with a VOM (volt meter). 15v charging after starting is ok for a short period of time.
MikeyB
Old Jan 26, 2007 | 01:22 PM
chrigu's Avatar
i have verify with fluke ,the engines ist hot
Old Jan 27, 2007 | 07:42 AM
MikeyB's Avatar
Once the batteries are fully charged the voltage should settle down to around 12.7-13v depending on the load.
My truck voltmeter is above 14v also after starting the truck and takes a while for it to drop back down.
MikeyB
Old Jan 27, 2007 | 10:11 AM
chrigu's Avatar
yes i have 12,7 volt the truck is off. but 15 volt when i have start the truck.
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
