silencer ring
Old Feb 25, 2005 | 04:34 PM
williejeeper7's Avatar
silencer ring
where is it and how can I remove it
Old Feb 25, 2005 | 05:57 PM
d0dg301's Avatar
Take off your air tube and it's on the inside of your turbo. You can pop it out with a screw driver or use a pair of needle nose pliers and it will come right out.
Old Feb 25, 2005 | 06:04 PM
Fronty Owner's Avatar
what is it?
Old Feb 25, 2005 | 06:08 PM
d0dg301's Avatar
Just a 3/4 round piece of spring steel that is in there to help tone done the whistle from the turbo when it spools up. I like the little extra sound it gives inside the cab. Doesn't do much of anything else.
Old Feb 25, 2005 | 06:27 PM
AirGrabber's Avatar
Do a search on " silencer ring removal" theres a guy who posted a bunch of pics of the ring and the removal. Doesnt do anything but quiet down the turbo whistle. Non existent in anything else with the same motor except the ram. While your at it, remove the baffles in the big black tube in between the two elbows. Only a muffler to help shut the turbo up, this is where you'll gain the most turbo music . Do a search for " intake muffler "
Old Feb 25, 2005 | 06:32 PM
Isn't that whistle part of the benefit of a turbo. To let everyone else know that the truck is about to come alive..
Old Feb 26, 2005 | 11:34 AM
kelley15's Avatar
It will sound like it does now . just more pronounced
Old Feb 26, 2005 | 11:50 AM
Vulcan's Avatar
Yeah, thats what I thought.
Old Feb 26, 2005 | 11:53 AM
Vulcan's Avatar
Hey Kelly, I like the last line in your sig.
Old Feb 26, 2005 | 12:24 PM
MikeyB's Avatar
I 'finally' got around and removed the silencer ring this morning. Slightly more turbine whine.
So now I just order a piece of 5" aluminum tubing from Air Flow Systems to replace the intake baffle.
MikeyB
Old Feb 26, 2005 | 12:34 PM
Desertrider's Avatar
Is there any performance gain to removing the silencer ring or intake baffle?
Old Feb 26, 2005 | 12:44 PM
MikeyB's Avatar
No performance gains. Just more noise.
MikeyB
Old Feb 26, 2005 | 04:23 PM
t-15 firefighter's Avatar
DTR's Self Appointed Beer Advisor
Re: silencer ring
Here you go!
here are a few pictures that will help you see what we are talking about.
silencer ring in front of the turbo
silencer ring and snap ring removed
trubo without the silencer ring
no performance gain whatsoever. just makes the turbo sing louder.
now that you have removed the silencer ring you need one of these:
MPC Intake Pipe
it will really be loud after this.
britt
Old Feb 27, 2005 | 07:32 PM
Lil Red's Avatar
Hey T-7 Firefighter, Where do you get the air intake tubing replacement from. Looks pretty clean. Gutted the baffles out but I'd like to replace it. Thanks.
Old Feb 27, 2005 | 08:09 PM
Right Here
hope this helps.
britt
