Sallyman is 1 step closer....
Old Mar 11, 2008 | 10:55 PM
sallyman1's Avatar
Ordered a quadzilla rail pressure gauge and the Lift pump pressure adapter today. Now im looking at a isspro 0-60 boost, pyro and tranny gauge and dash pod. then sallyman is going to DISCONNECT the edge juice attitude.
When i hook up new pyro should i put it where the edge pyro is?(use edge probe hole?) or put isspro probe after turbo?
Old Mar 11, 2008 | 10:58 PM
cbrahs's Avatar
use the edge hole. if you put it post turbo, it will be a lot lower EGT's that you will be reading and will not be a accurate comparison
Old Mar 12, 2008 | 12:46 AM
Big Blue24's Avatar
After you get some mechanical gauges, you're gonna dump the edge and get a smarty huh?
Old Mar 12, 2008 | 01:10 AM
matego's Avatar
madhat's monkey boy...
Isspro's probe is about 1 1/2 in. longer than the edge probe. I could not fit mine in the exh. manifold, only post turbo. Edge in manifold for fueling, Isspro post turbo for turbo cool down reference.
Old Mar 12, 2008 | 06:58 AM
sallyman1's Avatar
sure. maybe a smarty i dunno. the quad should be ok just that you have to toggle between RP and LP?right
Old Mar 12, 2008 | 09:12 AM
rip 112's Avatar
I used the probe that came with my banks kits to hookup to the Isspro. If it is a terminal kind wiring you should be fine hooking up to the probe you already have.
Old Mar 12, 2008 | 12:11 PM
Big Blue24's Avatar
Don't hook up to what you have because the point of switching is verify the validity of the EDGE readings. Put a small nipple or brass fitting of some kind to shim up the isspro if you have to.
Old Mar 12, 2008 | 01:24 PM
RamNu2's Avatar
Thats exactly what I did put a small crush sleeve on the thermocoupler then adjusted depth and tightened.
Old Mar 12, 2008 | 09:19 PM
sallyman1's Avatar
ok thanks. do u have a pic of the crush sleeve? i do wanna verify. im waiting for some feedback on gauges. the rail gauge should be here in 2 weeks. Is the rail quadzilla gauge easy to hookup? what does it hookup to? will it interfere withmy edge in any way?
Old Mar 12, 2008 | 10:39 PM
Cummins610's Avatar
It hooks between the sensor and the truck on top of the fuel rail,its a little hard to remove but it will come out. For the LP pressure you need to remove the banjo bolt on top of CP3 and replace it with the quad piece.
Old Mar 13, 2008 | 07:36 AM
06CTDforAU's Avatar
I didn't have to do anything with my Isspro pyrometer. It fit right in there just perfect. Maybe I got a different one or something?
SpitterGuy
Apr 1, 2009 06:35 AM
Diesel-Dan
17
Aug 4, 2006 09:51 AM
Scotty
Jan 30, 2006 05:56 PM
