Installing Commander Question
Old Mar 12, 2008 | 10:00 PM
bansh-eman's Avatar
When installing the Quad Commander are there any parts that you have to drill in order to install the sending unit for? or does everything already have the proper fittings and connections and you just tap into them?
Old Mar 12, 2008 | 11:54 PM
stealman1's Avatar
You need to drill and tape the exhaust manifold for the EGT prob.
Old Mar 13, 2008 | 12:07 AM
bansh-eman's Avatar
i was rading somewhere that you dont have to mount it there, that you can mount it behind the turbo and your temps will be slightly lower due to the turbo disapating some of the heat. is there already a spot that the fitting would mount to after or would you still have to tap it?
Old Mar 13, 2008 | 08:04 AM
tslewisz's Avatar
Not that I know of. It's not that big of a deal to drill and tap the manifold. It's a little scary if you've never done it before, but it really isn't that big of a deal.
stock03
Nov 9, 2006 11:27 PM
skydiver41
Sep 1, 2006 11:53 PM
HDBeauty
Aug 26, 2006 09:24 PM
RAMROD2006
Aug 24, 2006 10:47 AM
cumminsboy
Oct 25, 2004 09:35 PM
