??'s for guys runnin A5K/K31
Old Jul 29, 2007 | 11:12 PM
drasko's Avatar
if BW is making it for ats....i wonder if its as simple as a housing change minus the maching for the exhaust but id probably rather fabricate the exhaust to the turbo than vice versa... hell, it cant be that simple...thats too easy......but then again.....anybody know if there is a part # difference b/w the K31 exh. housing and the A5K ehaust housing? i might try to make my own for the heck of it.......anyone care to look for me?
drasko
Old Jul 30, 2007 | 02:13 AM
PourinDiesel's Avatar
Thats because it isnt.
i have been...so if you know how to answer my question "what does ATS do to turn the K31 into the A5K?" please do tell.....if not, thanks for wasting a response
drasko
Good way to make friends around here. Put the attitude away
The ATS Aurora 5000 uses a custom machined exhaust housing, custom exhaust outlet that bolts on, also ATS provides an outlet pipe for the turbo to connect to your intercooler. The kits for the Aurora's have changed a bit over the last couple of years. Most will have to do some fab work for the intake (as I did as well as others).
The A/R of the Aurora 5k is like .80-.90 T3 inlet
The A/R of the K31 Performance is 1.32 T6 inlet (huge)
The ATS unit is based off of a K31 Performance from Borg Warner....If you bought a A5K kit the K31 performance can be used a bolt in back up (sans the turbine housing) if the 5k fails...but ATS offers a 3yr/150k miles warranty with their 5k's.
The 5k is a good turbo but its not for the light hearted. It is big and laggy. You might be happier with a 66,64 or 62mm. The 5k has a 71mm compressor (you might know that already though).
***I think something is broken with the search option because I used to be able to find old threads of mine now I am hitting a dead end.
Old Jul 30, 2007 | 12:00 PM
chrleb1's Avatar
I don't think you'll like the A5K on the 94. It spools very well on the common rail because the common rail likes to spin big turbos. We put the A5K on a 600 hp 12 valve and it would bark, surge, and buck. If you have a lot of fuel on the common rail, you'll like it.
The only problem with the A5K on the 04.5 and up truck, is the low boost code.
Old Jul 30, 2007 | 07:18 PM
drasko's Avatar
pourindiesel, thats the kind of answers i was lookin for. thanx for the information, thats what i was lookin for.
im really not trying to get an attitude......it was just a lil smartars remark and i tend to say those alot but in regards for me saying it, i saw him say search the first time.....i didnt need "search search search" again. sorry if i hurt your feelings underwood......all i wanted was some info i couldnt seem to find on the housings....
thanx for the help folks
Drasko
Old Jul 30, 2007 | 09:26 PM
jwb600's Avatar
drasko that was an adult response I have respect for that. most guys on here will help you out alot. I know pourindiesel personally and he would also.
underwood kept trying to help you out he didnt get mad at you. that pretty cool of him I think
Old Jul 30, 2007 | 09:27 PM
jwb600's Avatar
did you install the resistor back in for the wastegate plug in? dont know if you tried that? I had to put one on my rig. you can get them from htt or Industrial Inj.
Old Jul 30, 2007 | 09:54 PM
chrleb1's Avatar
Yeah, we had one in. It would just through the low boost code every once in a while. Sometimes it just takes the right RPMs, right load, and a little low boost to make that code come up.
Old Jul 30, 2007 | 10:03 PM
turbopwr's Avatar
The a5k is fine on a standard, i wouldn't want one myself on an auto. Drives fine, lites soon enough. Never towed with it but it wouldnt faze me to put 10k behind it. What are you suppose to expect from such a big turbo, if you have problems with it its your own fault for not realizing what it was built to do.
cquestad
61
May 1, 2007 02:06 AM
BlackBeast
147
Apr 1, 2007 03:09 AM
OT-OF-Here
21
Feb 16, 2007 10:44 AM
Stealth Mode
Jun 9, 2006 08:42 PM
Buckshotmckee
Sep 12, 2005 01:25 AM
