The rundown on 11 TCs
as said,,as john said,,all can and will have problems sooner or later,,,,,,,stick with one vendor,,so warranty will be good.......i know you dont plan on a complete tranny now,but you will later.look at the complete package and decide now.go ahead and go with that companies con and vb now.and when the time comes,you can go with that complete tranny.........look at core charges also,if you decide to go with anothers tranny upgrade later,they wont take another companies convertor/vb for a core,,,,,.......good luck with it,,,,,,,,,bama
Originally Posted by omaharam
So, in the last two days I have called 11 different companies that supply torque converters for diesel light trucks. Let me first start by saying that I know more now than when I started calling, but am not sure I'm any closer to knowing which way to go. Of course, other than the TC itself, there are differing opinions on if an input shaft and flexplate are needed. It's about 50/50 on both of those issues. None the less, here is a rundown on which torque converters were recommended for my specific application - which is Edge JWA, will be doing exhaust and intake, tow 9000lb camper with 2000lbs in the truck.
SIDE NOTES
Rusty at TCS said that they have tested the input shaft strength and that at 1200 lbs it does not return back to original state after twisting (.046 off ), so around 1100 lbs is max engine torque for stock shaft. Was very helpful and willing to talk. ( by the way, the billet shaft at 2200 lbs had a difference of .002)
Dave at Goerend gave me the most information over all as far as explaining why they do what they do, how it all works, etc. Also very willing to talk.
Stephan at DTT is of course, looking below, the only one that recommended a single disc converter, but makes a very strong case for it. He also was very informative and helpful but of course with ideas that differ from most of the other vendors. Also pretty willing to talk.
The rest of the guys basically didn't give any information unless I specifically asked. With Rusty, Dave, and Stephan it was a conversation. With the others it was a question and answer session.
TCI - 3 disc $1114 2yr warranty
Banks - 2 disc 2yr warranty $1439
Dunrite - 3 disc $1360 lifetime warranty, yes on shaft, no on flexplate
DTT - single disc $975 2 yr warranty, border line on shaft, no on flexplate
TCS - 3 disc $1150 2 yr warranty, border line on shaft, no on flexplate
ATS - 5 disc $1388 forgot to ask about warranty, yes on shaft and flexplate
Suncoast - 3 disc $1295 warranty ?, yes on shaft, border line on flexplate
Goerend - 3 disc $1200 lifetime warranty furnaced braised/ $1050 100,000 mile warranty not furnaced braised(said this would be ok for me aside from warranty) no on shaft, no on flexplate.
Precision Industries - 3 disc $1043 2yr warranty
BD - 2 disc $1195 2yr warranty, no on shaft, no on flexplate
B&M - lost my notes on this one but was 3 disc and pretty sure $1250 and don't remember warranty
I'm exhausted
and confused
and a little frustrated
that I still don't know where to spend my money. I like what Stephan had to say, but it's only a 2yr warranty. Maybe I'll just take the box off and go stock so I don't have to mess with the tranny at all.
Just kiddin' - I like power to much for that!
SIDE NOTES
I'm exhausted
and confused
Omaharam, My thought is the shop that claims do the same for Less, example:I have two customers (Farther Son) Both are very aggressive in the WOT practice,T&C WAS considerably higher than a local Transmission shop that only does transmission work only (No Performance Products) and is not know for performance.I look at Their Estimate,It stated upgraded transmission @ $$.They return to the local trans shop and Both customers stated My concerns and to Quote:I can do the same as T&C for Less,We"ll the TC they install is so lose and sloppy the Tuner"s default to stock.Both return and were given the *^$. All the companies you mention are Known for Upgraded Performance Transmissions...
Just My Opinion,If I ever Build a Race Track only truck, it will be a 100% DTT Build.
Originally Posted by got...DIESEL?
most multi disk companies would like to see a billet plate....but for reasons not yest brought up. The extra weight of a triple with a billet front cover!! Stock plates will flex too much and the added weight will casue havok on the pump and front seal if the flexplate can't control it!!
Just had a phone conversation with Dave at Goerend. Learned a lot. He is a great guy. He spent that much time on the phone with me just answering questions and offering information (some of it he doesn't even like to share, but i was asking the right questions and being persistant) without even knowing if I was going to order anything. I DID!
Originally Posted by banshee
I hope DTT didn't tell you that, because they're just coming up with untruths if they did. The splitting of pressure over the disks is completely incorrect. If Bill or Stephan really believe that then they need to spend some time in an engineering statics class to learn about how multi disks work. The multi disks are also rebuildable, at least ATS' are, albiet they may be more expensive to overhaul. The problem of them coming apart or burning up one disk or causing the whole tranny to melt down is also bogus and has been proven to be wrong by dozens and dozens of trucks with millions of miles between them. When ATS first came out Bill said after 30,000 miles the converter would come apart and would sound like the same as if you loosened all the bolts holding the converter to the flexplate....
There are trucks with well over 10 times that amount of mileage without a hint of that problem.
There are trucks with well over 10 times that amount of mileage without a hint of that problem.100 PSI pressure behind the piston of a single disk will yield the EXACT same force & pressure on EACH of 3 clutches in a triple disk. Furthermore, each clutch in a triple clutch converter will hold the exact same engine torque as the 1 clutch in a single disk converter (3x holding capacity). This is just simple statics! Read some of my old posts, I've given all the theory and math needed to make your own educated decisions. EVERY clutch pack in the this transmission uses multiple clutches - and a lot more than 3 clutches I might add. Ask Bill and Stephan why they add more clutches to EVERY clutch pack in the transmission if their theory about pressure drop holds true! Why would a TC clutch be any different?
Flow problems? Why? Wouldn't the designers of the TC set up the clearances for adequate flow? With 100+ psi of pressure, flow and lubrication is not an issue if designed properly - period. There are plenty of guys drag racing, sled pulling, towing, commuting, and just generaly abusing thier trucks with multi disk converters that do not have these issues! Could you imagine the cost of the constant warrantys that these companys would be getting if this were ture? It just wouldn't make good business sense for 90% of the TC manufactures you called to be doing this!
Higher rebuild costs - I doubt it. For starters, DTT uses a bone stock cover and piston (at least the ones I've seen cut apart). This means they are having to scrape off a friction from the stock piston, clean and reprep the surface to get a good bond on the piston - then bond it on a weird shaped piece of steel - lot of time required. Most muti disk converters I've seen have the frictions all bonded to the steels. Throw away 2 steels, install new ones and your done. So, DTT's got some money wrapped up in labor and everyone else has a few bucks wrapped up in 2 steels. Everything else on the rebuilds will be almost identical. Rebuilding a converter is not expensive from a materials point of view, its just a lot of labor. Lets ask for a price breakdown between some of these manufactures, I bet they will all be about the same - single, double, triple clutch - you name it. Regardless, most of these companies give you plenty of time and miles to get all the bugs worked out - the rebuild cost is on them during the waranty period.
Its pretty sad to see a company spreading mistruths while attempting to hurt the image of another company just to get a sale. I've heard it too many times from these guys - Its getting really old.
I have no idea if this is true or not, but I was told that the design of our set up is that the there is a hub on the TC that rides in the back of the crank. This is not like any set up I am familiar with. This means that the weight of the converter is supported by the crank and not the flexplate. That means that the weight of the converter does not matter. This is what I understood. If anyone knows this first hand, please confirm.
I think you'll be real happy with your decision to go with Goerend!
The flexplate is bolted up to the crank (smaller circle of bolts) and the cover of the TC bolts to the flexplate (large bolt circle). So, its all related. I wouldn't worry about it much, there aren't too many people that are breaking flex plates, at least I'm not hearing about it. Its typically your REAL high HP crowd or the boys that tow ridiculous amount of weight often that are breaking them. And pump seal and pump issues???? Again, don't think this is a big deal - these problems are all probably just flukes. Billet flex plates have not been the norm until recently. There have been many years of OEM flex plates with few related issues.
How long is the warranty good for on most cars - 36,000 - 60,000 miles - yes there are a few doing 100. The point is, they know when crap will start to go wrong. That is why most of the companies selling converters (single or triple) only give you a 2yr warranty. Not to say that if it's going to fail it won't happen right away, but from a wear standpoint, a five or ten year old converter that is still under warranty isn't neccessarily good business sense either - hense the common warranty period of 2yrs
Actually, talking to Dave, he has seen broken flexplates. However, the reasons that are normally thrown around as to why are somewhat vague. Dave gave me a lot of good insight on why they break - both around the crank and out further where the conveter bolts are. His logic is much more sound. I did not purchase a flexplate, only the converter and VB.
Originally Posted by Syndicate
Its my understanding that the flexplates in the newer (04-05) trucks are much lighter duty that the older trucks which is why aftermarket flexplates are becoming more common.
The issue is alignment and clearances that are not all the same from the factory, such as the allignment pins, and a couple other "secrets" I was asked not to share publicly. I am confident that after putting the Goeremd parts in my truck and doing some inspecting, I will not have any issues.
Question for all of you tranny guys. If you do an after market tc and vb does it hold the truck back more (when towing or on hills) than when stock even with the converter locked up? If so is it simular to the torqueshift or allison trannies?
On the whole flexplate deal, I have personally seen 3 go bye bye and know several others that have had them let go. These were all in well used trucks, if your good to it I'm sure you can get by with the stocker but what fun would that be
C Minus
16
Dec 18, 2007 03:43 PM
Igor
Oct 8, 2005 11:17 PM
