Removing the plastic cover on an 06
Old Feb 4, 2008 | 03:38 PM
CDoskocil9's Avatar
Can you remove the black cover on top of an 06 like you can an 05 and run it with the bare metal cover and vent showing??? Is that what is under the black plastic on the 06's??? Anything I should know what holds the plastic on??? Thanks
Old Feb 4, 2008 | 04:47 PM
homewrecker's Avatar
If its the same as an 05,just 4 bolts(10mm socket) and thats it.You will see the breather box a tube though.
Old Feb 4, 2008 | 04:48 PM
mizzu's Avatar
Anybody Got Pics?
Old Feb 4, 2008 | 04:54 PM
cbrahs's Avatar
matego has done it (if i recall correctly) and has pics. I think he re-routed the breather tube and it looks clean.
Old Feb 4, 2008 | 06:17 PM
Dieselhed's Avatar
Here ya go....
Old Feb 4, 2008 | 06:19 PM
Timinva's Avatar
DTR Advertiser
On a 06 you can not run it without the black plastic. The black plastic is the upper valve cover, it is not a dress up part. Tim
Old Feb 4, 2008 | 06:27 PM
Originally Posted by Dieselhed
Here ya go....
Looking good Dieselhed
but seriously,maybe this would interest you
https://www.dieseltruckresource.com/...+cover+project
Old Feb 4, 2008 | 07:21 PM
CDoskocil9's Avatar
Tim please explain upper valve cover so if you pull the plastic you see springs injectors oil lol thanks for the help
Old Feb 4, 2008 | 07:56 PM
Timinva's Avatar
DTR Advertiser
The pictures shown are 03-05 trucks.06 and 07s the upper valve cover/ breather are one piece all plastic. If you remove the platic top on a 06 you will see rockers, springs and inj wiring harness. 03-05 have the plastic piece that is nothing but a breather cover / dress up piece. Tim
VACHZHD
Sep 13, 2012 07:39 PM
rjweiss
Mar 26, 2011 08:03 AM
rjweiss
Feb 12, 2009 06:27 AM
rjm022
Feb 4, 2006 08:02 PM
Cummnzpowr
Sep 10, 2003 12:42 AM
