raptor 150 question
raptor 150 question
OK i got the raptor 150 and a liberty canister mod from Vulcan performance and put everything in my truck.
truck runs good and everything but when i go to start the truck it takes awhile to prime up the fuel system is this normal for the fuel system to bleed back to the tank or should it stay pressurized?
krazykiller
krazykiller
If you tapped into the factory wiring for the stock pump you dhould hear the pump run for a few seconds to pressurize things when you turn the key, so it should fire right up.
Can you hear the pump run when you turn the key to on?
White97GTVert
13
Apr 21, 2011 08:51 PM
goose2w1
Feb 29, 2008 08:45 AM
84mphcdt
16
Dec 19, 2007 11:31 AM
