Raptor 150 install wiring question
So I got the raptor 150 w/ drawstraw and 1/2 line all the way to the injector pump.
It was an easy install except when it comes to the wiring, the instructions say connect the raptor ECM lead to the
ECM pump lead.
I don't follow this part. I turned the key on and found no power in the two wire lead that is behind the filter housing, does the key need to be in the start position to see power to the stock pump?
Thanks
ECM pump lead.
Thanks
What you want is the connector that connected to the oem lift pump connected to the relay. it only should have voltage when you turn on key for about 2 seconds, and if you 'bump' the started for 20 - 30 seconds.
raptor 150
Thanks for all the help, got it going.
Just key to on position gives 12v for 1/2 second, bump the starter and you get 12v for 30 sec.
I was leary of bumping the starter w/ all the fuel drained from the system, but thats what it took, just keep doin that till you get fuel to the inj. pump.
Thanks again,
T
Thanks again,
T
White97GTVert
13
Apr 21, 2011 08:51 PM
FullOutPwr
15
Oct 30, 2008 09:06 PM
goose2w1
Feb 29, 2008 08:45 AM
