Dumb question about Airdog Raptor 150 install
I'll be installing the unit this weekend and have a question about the stock fuel supply line that is left over(the one from the tank to the now removed OEM lift pump). Since you have to drill a whole for a new suction tube, what do you do with the old one coming off the fuel tank module? Do you just cut it short and plug it off? Or am I missing something
I dont think its a dumb question. im sure when someone gets on here they will answer your question. I dont have that fuel system but I have been looking at it pretty hard if I end up keeping my truck
You can do that or you can talk to your local dealer and get the pick up assembly from an earlier model truck. That is what I had to do because my LP was going out and the dealer changed mine to the in tank style without asking. I now have the old parts and am getting an aftermarket LP.
?or you can leave it all attached and disconnect the outlet line on the filter housing and cap it there.(witch means you take the supply line from the cp3 to the filter off and put it in your garage or something)
clear as mud?
CrashCade
Dec 3, 2008 07:58 AM
53 willys
38
Nov 6, 2008 11:18 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
84mphcdt
16
Dec 19, 2007 11:31 AM
