Rail Problems
Old Apr 11, 2008 | 10:40 AM
Silver 002's Avatar
Rail Problems
I know Old Smokey and I had this going but i cant find our original thread. My 04.5 is having some issues...
First when stacked with orignal smarty tune and mp-8 i couldnt hold my rail above 19000 it would spike after i let out of it and hit 20 21 with mp-8 at 100%.
I had TS check over the MP-8 and they found it to be all good. Then with beta 4.3 and mp-8 100% Same results under full throttle the rail would drop when first hit then struggle to climb to 19ish then spike to 25 26 after I let out.
Then 65-80 cruising rail holds at 20 with beta 4.3 mp-8 0%.I think i have seen a couple guys complain that this is part of the 4.3 program but when i returned the pickup to stock and mp-8 0% i still see 17 at that speed. isnt this high?
Any thoughts are much appreciatted. cp3 is untouched, fuel pressure right before cp3 is 18-20. We did test the RV but seemed to check out ok.
Old Apr 11, 2008 | 10:46 AM
OldSmokey's Avatar
Heres somemore stuff to read Zach
https://www.dieseltruckresource.com/...d.php?t=200437
Old Apr 11, 2008 | 12:42 PM
Silver 002's Avatar
thanks joel, so i guess 17 is right in normal. im guessing with 1.5s stock it will be down. but i still think that we have a weak link some where...cp3 to injectors/rail area. anyone else have a suggestion. i guess our next plan is to cap the rail to again make sure then attack the fca/cp3.
Old Apr 11, 2008 | 02:24 PM
offroadalliance's Avatar
when my filters restrict or the pump weakens my rail pressure will do the same thing.
P.J
55
Apr 18, 2020 11:51 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
sallyman1
Feb 14, 2009 12:30 AM
5.9Excursion
Mar 13, 2008 10:56 AM
out4elk
20
Aug 26, 2007 12:53 PM
